Re: 07 Grand Caravan rear disc brakes
[Re: cantspel]
#568639
01/01/10 11:21 AM
01/01/10 11:21 AM
Posts: 714 USA
Lawn Monkey
USA
If you have an 07 (RS), the ebrake shoes are drum style under the rotor. You can check them when you pull the rotors to have them turned or replaced, then readjust as you would any drum brake system. It really has nothing to do with your disc brake system as it is a seperate brake. If you have and 08 (RT), Your ebrake cable will go into the caliper. The caliper will need to be pressed in and spun clockwise at the same time.
Thank you ,,,,,,, I have a regular Grand Caravan not an RS or RT , hope I have the brake drum type (Sounds simple).......
Thank you appreciate the help
[Re: Lawn Monkey]
#568640
01/01/10 03:20 PM
01/01/10 03:20 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
RS/RT I think is the body designation (like the '94-01 rams are BR's the sebring stratus were JA's, the redesign are JH's, etc
[Re: patrick]
#568641
01/01/10 08:43 PM
01/01/10 08:43 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Just look at the park ables.If they arent attached to the calipars it has the drum type park brakes.The ones that screw in are easy also as long as you have the tool.Rocky
Chrysler Firepower
