Page 1 of 3 1 2 3
Just installed the new Unlawful frame conectors #568073
12/31/09 07:35 PM
12/31/09 07:35 PM
Ortonville, MI
RoadRnnr69 Offline OP
Keyster
Keyster
Ortonville, MI
These went together in about an hour including taking out the old bars and driveshaft loop.
These are all integrated with a new drive shaft loop.
Thanks guys!!!
Re: Just installed the new Unlawful frame conectors [Re: RoadRnnr69] #568074
12/31/09 07:51 PM
12/31/09 07:51 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
nice pics and looks like a very nice frame kit.
Re: Just installed the new Unlawful frame conectors [Re: blownzoom440] #568075
12/31/09 10:40 PM
12/31/09 10:40 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Sweet looks good
Re: Just installed the new Unlawful frame conectors [Re: B1KILLER] #568076
12/31/09 10:52 PM
12/31/09 10:52 PM
That looks nice, but isn't the loop supposed to be farther back from the U-joint?
Re: Just installed the new Unlawful frame conectors #568077
12/31/09 11:00 PM
12/31/09 11:00 PM
Renton Washington
Triple Threat Offline
Renton Washington
No, must be within 6" of the u joint.
In place of a
crossmember, in the vicinity of the front universal joint, all cars in
competition using open driveshafts must have a retainer loop 360
degrees of enclosure, 1/4-inch minimum thickness and 2 inches
wide, or 7/8-inch x .065-inch welded steel tubing, securely mounted
and located within 6 inches of the front universal joint for support of
the driveshaft in event of U-joint failure. Open drivelines passing
any part of the driver’s body must be completely enclosed in 1/8-
inch minimum thickness steel plate, securely mounted to the frame
or frame structure. Driveshaft loop required on all cars running
13.99 (*8.59) or quicker and utilizing slicks; except vehicles running
11.49 (*7.35) seconds or slower equipped with street tires.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Just installed the new Unlawful frame conectors #568078
12/31/09 11:02 PM
12/31/09 11:02 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Unreal looking. Looks great. Looks like it would stiffen it up. A lot better than stock, thats for sure.. Congrats. Jack is putting out some great quality..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Just installed the new Unlawful frame conectors #568079
12/31/09 11:44 PM
12/31/09 11:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you look you will see that the front yoke is pulled
back(the rear end is hanging down on the shocks).
Looks good
Re: Just installed the new Unlawful frame conectors #568080
01/01/10 08:33 AM
01/01/10 08:33 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
It might meet the rules, but I think a better location would be slightly to the rear, if with a u joint failure the driveshaft whips around, flexes a bit, it will figure a way to slip out and then it will be like having no loop at all.Should be an easy adjustment for future installations, or is it adjustable, can't quite make out that detail. What do the 2 6" bolted plates in the rear attach to? The frame connectors and/or a bolted in roll bar?
Nice car, nice & easy? installation, but seems to have a few compromises in the design IMO.
For many years I have asked can anybody explain with data what exact forces the subframe connectors resist? Bending, torsion, compression, tension, and in what directions/combinations, because that knowledge will much clearer define the actual design of the actual subframe connector, and still no answer.
Re: Just installed the new Unlawful frame conectors [Re: RoadRnnr69] #568081
01/01/10 10:19 AM
01/01/10 10:19 AM
central new york
pettyblue440 Offline
central new york
are they just bolted in or welded as well? looks good
Re: Just installed the new Unlawful frame conectors [Re: pettyblue440] #568082
01/01/10 10:28 AM
01/01/10 10:28 AM
Ortonville, MI
Keyster
Keyster
Ortonville, MI
This 100% bolted in, the driveshaft loop is adjustable and will slide back just by loosening the clamps on the rails.
Re: Just installed the new Unlawful frame conectors [Re: RoadRnnr69] #568083
01/01/10 10:34 AM
01/01/10 10:34 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I maybe wrong but bolted in I don't see it doing much(better than nothing I guess) except for looks. if it's not welded into the floor pan I bet it will still flex. but it does look good
Re: Just installed the new Unlawful frame conectors [Re: blownzoom440] #568084
01/01/10 10:53 AM
01/01/10 10:53 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Nice,,,,any plans for a X or H pipe for the exhaust ?
What mufflers you have on there now ?
Nice job......
Re: Just installed the new Unlawful frame conectors [Re: 69CHARGERMD] #568085
01/01/10 11:32 AM
01/01/10 11:32 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Does this mean you went a 10.96 without subrame connectors before? Do you have a rollbar?
Were you starting to have problems with body flex/doors not closing, that kind of thing?
Re: Just installed the new Unlawful frame conectors [Re: 67Satty] #568086
01/01/10 12:17 PM
01/01/10 12:17 PM
ELYRIA,OH
ELYRIA,OH
i think 1 way to see if thay help would be to jack up the car with them on then without and measure the flex before the tire lifts off the ground.mine with a 10pt cage will lift 6" before both fronts lift off jacking from 1 side.the sq tube kit sold that bolts in does the same thing as the round kit pictured.
Re: Just installed the new Unlawful frame conectors *DELETED* *DELETED* [Re: jcc] #568087
01/01/10 12:41 PM
01/01/10 12:41 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Post deleted by polyspheric
Boffin Emeritus
Re: Just installed the new Unlawful frame conectors [Re: polyspheric] #568088
01/01/10 01:00 PM
01/01/10 01:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes, I agree, but I also mentioned "compression", and that it might also be a factor in that the front leaf spring attachment point is basically pushing the entire chassis forward with all the multiplied force the motor can develop, and that force then flows thru the floor pan (which is nearly useless) and also makes effectively, 2 90Deg turns as it flows thru the rocker panels, which is I suspect what boxing them achieves/improves, but not likely very effectively, so what the aftermarket subframes may accomplish best is direct compressive transfer of the actual acceleration of the car, and then the shape/ diameter is not quite as important, but of course only in regards to this force (ie not bending). IMO there is lot going on here, and no solution is ideal until those forces are understood and weighed, and the application taken into account. It seems for years there have only antedotal solutions and monkey see, monkey do, and no one asks why?
And isn't the twist from "planting" the left rear, not the right?
Re: Just installed the new Unlawful frame conectors [Re: jcc] #568089
01/01/10 01:31 PM
01/01/10 01:31 PM
K
Kiddart Offline
Kiddart  Offline
K
Another great product.
LOOKS FANTASTIC JACK!!
Kiddart
Thank you
Kiddart
Re: Just installed the new Unlawful frame conectors [Re: jcc] #568090
01/01/10 01:35 PM
01/01/10 01:35 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Does anyone have any empirical evidence, like before and after subframe connector time slips or pictures pf body damage that resulted from lack of connectors to post?
Just curious about how much they are worth to lowering ET. A tenth? Two tenths? More?
Re: Just installed the new Unlawful frame conectors [Re: RoadRnnr69] #568091
01/01/10 01:39 PM
01/01/10 01:39 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Where do you buy this fine product???
Re: Just installed the new Unlawful frame conectors [Re: ThermoQuad] #568092
01/01/10 03:45 PM
01/01/10 03:45 PM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
I do believe this is where you can go to get them...
www.unlawfulracing.com
I believe he also installs them? Whichever the case if Jack Irons builds something its fast and it works.Didn't he have the first 10 second FAST car or something like that?
Page 1 of 3 1 2 3
