Page 4 of 6 1 2 3 4 5 6
Re: 505 back together with Mancini heads [Re: AndyF] #56802
06/06/08 08:54 PM
06/06/08 08:54 PM
AndyF Offline OP
AndyF  Offline OP
We put this Braswell 1.590 venturi 4150 carb on there. It basically made the same power as my UltraHP 4500 carb. Usually the 4500 makes about 20 hp more than the 4150 but at these power levels maybe it doesn't matter so much.
Peak torque was 637 at 4000 rpm. Peak power was 670 hp at 6100 rpm. Pretty typical torque curve for standard port heads on a 500 inch motor but the power hung on for longer than I expected.
Re: 505 back together with Mancini heads [Re: AndyF] #56803
06/06/08 08:57 PM
06/06/08 08:57 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I hope you do....I noticed a few years ago that with long 4.25" arms if you slightly overcam (by like 8 degrees @ .050) and move the cam up to 101-102 makes better overall power (makes more up top and as much or more off the bottom) than a conventional 106-108 ICL...if you do the math the Intake closing works about the the same as a smaller/later but I believe it's just getting the valve to peak earlier in the induction cycle that makes a big wedge happy.
WIZE
In Car:
Re: 505 back together with Mancini heads [Re: Streetwize] #56804
06/06/08 11:28 PM
06/06/08 11:28 PM
Hey Andy,
Will those breathers fit under the hood like that??? or is the motor going in a dragster.......
Re: 505 back together with Mancini heads #56805
06/06/08 11:54 PM
06/06/08 11:54 PM
AndyF Offline OP
AndyF  Offline OP
Dyno mule motor, probably won't ever go into anything.
Re: 505 back together with Mancini heads [Re: BradH] #56806
06/07/08 09:02 AM
06/07/08 09:02 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Now, lets talk about the B block version of that intake!! Nothing in inventory anywhere for the B intake.
I recall MP having a "blowout" deal on those things years ago, which probably depleted the inventory. I think that was about the time someone from here sent me one to throw on my flow bench, too.
Years after the blowout deal, Andy and I caught the B intake headed into NS1 status here just recently which we thought was a bad idea. We managed to get the discontinued ruling reversed/part number brought back after a short discussion with MP. Doubtful it was ever a huge seller for MP but for that application that intake was the only game in town, and it may become popular at some point as big ci combinations become the norm. MP actually does have a little bit of inventory on the casting itself, just not the complete package number at this point.
Rich H.
Esse Quam Videri
Re: 505 back together with Mancini heads [Re: ZIPPY] #56807
06/07/08 11:17 AM
06/07/08 11:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what intake is this you guys are talking about ?
Re: 505 back together with Mancini heads [Re: JohnRR] #56808
06/07/08 04:06 PM
06/07/08 04:06 PM
AndyF Offline OP
AndyF  Offline OP
That discussion was around the 724 intake which is the B version of the 725 intake that I'm running on this motor. Those are the M1 intakes with standard runners and 4500 flange.
There is also a RB intake with Max Wedge runners that Mopar used to make that they might bring back. I think it was just a 4150 flange though. Kind of funny, MP had these intakes around before there was much demand for them so they killed them off. Now there are a bunch of motors being built that can use the big carbs and big runners so the intakes are coming back.
Still no one makes a RB (or B) dual plane with 4500 flange. I'd run one on this motor if it was available.
Re: 505 back together with Mancini heads [Re: AndyF] #56809
06/07/08 04:40 PM
06/07/08 04:40 PM
"That discussion was around the 724 intake which is the B version of the 725 intake that I'm running on this motor. Those are the M1 intakes with standard runners and 4500 flange."
It was nice to buy the intake for $81 during closeout.
"Still no one makes a RB (or B) dual plane with 4500 flange. I'd run one on this motor if it was available."
I would send you my CH440 to use but someone trashed it in a magazine article and I can't hardly give it away.
Re: 505 back together with Mancini heads [Re: AndyF] #56810
06/09/08 09:34 PM
06/09/08 09:34 PM
AndyF Offline OP
AndyF  Offline OP
We did a bunch more pulls today trying different things. The "trick" carb is consistently down 50 hp regardless of what we do with it. We tried different jets, plugged the power valves, messed with air bleeds, etc. It just sounds bad and runs bad.
With the UltraHP Dominator back on there the motor cranked out 680 hp at 5800 rpm. Best torque was 637 at 4000 rpm.
Re: 505 back together with Mancini heads [Re: AndyF] #56811
06/13/08 08:54 PM
06/13/08 08:54 PM
AndyF Offline OP
AndyF  Offline OP
Put the 505 back on the dyno today and made a bunch more pulls with the Super Victor intake. Nice looking intake, it is quite a bit taller than the M1 intake. Power output appears to be roughly the same between the two intakes.
Re: 505 back together with Mancini heads [Re: AndyF] #56812
06/13/08 09:03 PM
06/13/08 09:03 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
so an intake that has been available for a number of years from Mopar is making the same power as the latest from Edelbrock?
I used it because I wanted to run the carb I am using and it fit under the hood.
I also copied my engine from the chuck senatore book and it was his intake of choice.
Re: 505 back together with Mancini heads [Re: Joshs68] #56813
06/13/08 10:57 PM
06/13/08 10:57 PM
AndyF Offline OP
AndyF  Offline OP
Well just becuase the power output was the same on this motor doesn't mean there couldn't be a big difference on another motor. The Super Victor runners are a lot longer than the M1's runners so on some motors I'd expect to see a difference in the torque curve.
On a smaller displacement motor there might be a bigger difference since the torque peak would be at a higher speed and the motor might care more about the length of the runners. On a 505 motor the torque peak is at 4000 rpm so maybe the length difference isn't significant.
Re: 505 back together with Mancini heads [Re: AndyF] #56814
06/15/08 02:18 AM
06/15/08 02:18 AM
nebraska
roadrunner470 Offline
nebraska
I have a dumb Question, are these MW or std port head
Re: 505 back together with Mancini heads [Re: roadrunner470] #56815
06/15/08 10:26 AM
06/15/08 10:26 AM
IN
Dartman928 Offline
Dartman928  Offline
IN
Andy,
Can you tell us who's "trick" carb is down on power?
Re: 505 back together with Mancini heads [Re: roadrunner470] #56816
06/15/08 10:47 AM
06/15/08 10:47 AM
AndyF Offline OP
AndyF  Offline OP
Standard port heads.
The carb that was way down on power wasn't mine, it belongs to the dyno operator. We eventually solved the carb problem by changing the metering blocks although we never did figure out what was wrong with the original metering blocks.
Re: 505 back together with Mancini heads [Re: AndyF] #56817
06/19/08 02:02 PM
06/19/08 02:02 PM
indiana PA
moparbob498 Offline
moparbob498  Offline
indiana PA
have you tried the std. M1 single plane w/4150 flange & adapter w/ Dominator combo? i read in a Mopar Muscle that it was 25 hp over the std. 4500 flange int.----i can say going from the Team G to the above set up i questioned about my car went from 10.90 to 10.71---so the Team G went down the road.
mopar or no car
Re: 505 back together with Mancini heads [Re: moparbob498] #56818
06/19/08 02:16 PM
06/19/08 02:16 PM
AndyF Offline OP
AndyF  Offline OP
No, I didn't try that. It would be interesting to try a four way test with something like the Victor 440, Super Victor manifolds and then the 4150 and 4500 carbs.
At this power level I'll take a guess and say it doesn't matter which combination you use. I could be proven wrong but my guess is it won't really matter much.
We did try a 4150 carb on the M1 intake using a Wilson adapter. Basically there wasn't much power difference. I've done dyno tests in the past using a 4150 intake with an adapter to a 4500 carb and haven't really seen much diffrence either.
I don't doubt that some people have seen a 15 or 20 hp improvement when using a 4500 carb on a 4150 intake but I don't think it is a general rule. I'd say it is something that can happen on a certain combination but it isn't something that will happen.
Remember, I just did some dyno testing. It is quite possible that one of the combinations would get a car down the track quicker even though the dyno numbers don't look any different. One intake might have better shift recovery or something like that. Or sometimes, on cars with poor traction the intake that has less torque on the low end will run better at the track.
Re: 505 back together with Mancini heads [Re: roadrunner470] #56819
06/19/08 05:08 PM
06/19/08 05:08 PM
AndyF Offline OP
AndyF  Offline OP
Not a dumb question since Jeff at Modern has both MW and standard port programs. I didn't go with the MW ports since these heads are supposed to go on my street motor whenever that gets back on track.
I am thinking seriously about putting the EZ heads back on this motor but leaving this street roller camshaft in there. So that will then have the 1.70 Jesel rocker arms and the larger parts. It would be interesting to see how much power the motor would pick up from that swap, probably push it back up to 750 hp or so.
If I did that I could try out the new MW sized Super Victor intake. Maybe even try the P4876337 intake if Mopar Performance re-issues it. Zippy, you out there? Any word on the 337 intake?
Re: 505 back together with Mancini heads [Re: AndyF] #56820
08/04/08 01:24 AM
08/04/08 01:24 AM
AndyF Offline OP
AndyF  Offline OP
I picked up a Holley Street Dominator intake and a new Holley 1000 hp carb to try on this motor. I haven't ever run either of these items so it should be fun. The 1000HP has 1.56 bores which is getting right up there. I've run a 1.59 Braswell carb before on this motor and it works pretty well.
I'll have to get a street motor back together to try some of this stuff on the road. I wonder what the 1000HP works like in traffic with those big bores.
Re: 505 back together with Mancini heads [Re: AndyF] #56821
08/04/08 10:24 AM
08/04/08 10:24 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
IIRC, out of the box the 1000 HPs tend to run rather "fat". I'll be interested in how much tuning you have to do to get it to run clean under your test conditions.
