1993 Cummins with noisy 4th gear Getrag #567485
12/30/09 10:50 PM
12/30/09 10:50 PM
San Diego
formula S Offline OP
San Diego
Under light load and when you coast it makes noise. Have any of you had this problem, if so what did you do to fix it
Re: 1993 Cummins with noisy 4th gear Getrag [Re: formula S] #567486
12/31/09 08:47 AM
12/31/09 08:47 AM
North Carolina
jt1 Offline
jt1  Offline
North Carolina
The Getrag's use a bearing race machined into the rear of the input shaft, rather than a standard bearing cup. When it wears, you have to replace the input shaft along with new bearings. I don't know the current price, but the input shaft is fairly expensive. It will probably run quite a while as is, but if it bugs you it's probably cheaper to find another trans.
John
