Bilstein/Edlebrock/QA1 shock decision #566392
12/29/09 10:55 PM
12/29/09 10:55 PM
Los Angeles
Hazwoy Offline OP
Hazwoy  Offline OP
Los Angeles
Need help with my shock decision. My car is 1972 Dodge Charger with rebuilt 1990 360 motor. 9:1 stock or small upgrade cam. Davis HEI Ignition, Holley street avenger carb. Stiff suspension and ride with heavier springs, shocks, torsion and sway bars, 18" wheels, 45 series tires. Driven daily on street only, rough roads here in urban L.A. Currently have KYB's, 6 years old (50k miles).
Edlebrock shock look good with dual valving. Looking for best street shock with performance for the junky streets here.
What do you guys think?
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Hazwoy] #566393
12/29/09 11:38 PM
12/29/09 11:38 PM
calif
cupcake Offline
cupcake  Offline
calif
FRONT & REAR COIL OVERS
Re: Bilstein/Edlebrock/QA1 shock decision [Re: cupcake] #566394
12/29/09 11:52 PM
12/29/09 11:52 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
QA1
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Hazwoy] #566395
12/30/09 12:13 AM
12/30/09 12:13 AM
AndyF Offline
AndyF  Offline
The Edelbrock shocks would be a good choice or call Firm Feel and get their shocks. They have custom Bilstein shocks that are made for Mopar applications.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Hazwoy] #566396
12/30/09 01:55 AM
12/30/09 01:55 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Ned help with my shock decision. My car is 1972 Dodge Charger with rebuilt 1990 360 motor. 9:1 stock or small upgrade cam. Davis HEI Ignition, Holley street avenger carb. Stiff suspension and ride with heavier springs, shocks, torsion and sway bars, 18" wheels, 45 series tires. Driven daily on street only, rough roads here in urban L.A. Currently have KYB's, 6 years old (50k miles).
Edlebrock shock look good with dual valving. Look for best street shock with performance for the junky streets here.
What diameter torsion bars do you have?
What are your exact tires sizes front and rear.
QA1's are expensive and may be overkill for what you have. How do you currently like your KYB's?
I driven the same streets as you in the LA basin since 1993 in my Barracuda. I have 1" T-bars that is about 10% stiffer than a B-body 1"bar and the A-body is lighter. My commute for a few years wasm 80 mile round trip from 10Fwy/LaCienega to Westlake Village.
Roads out here are pretty good for a metropolitan area. My brother lives in metro Boston. He's gotten a flat tire and bent steel rim on a Boston Pothole.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: autoxcuda] #566397
12/30/09 04:41 AM
12/30/09 04:41 AM
Los Angeles
Hazwoy Offline OP
Hazwoy  Offline OP
Los Angeles
Front is 18 X 8”, 245/45-18, rear 18 X 10”, 295/45-18. ARE Torq Thust II aluminum wheels. Torsion bars are 1.00” dia. Car is lowered but not excessively. HD440 rear springs. KYB shocks seemed pretty good but I took a big dip at freeway speeds the other day (Highland exit from 101 south) and car bounced as if it really bottomed out hard which it had never done before so I am think shocks are a bit worn. Shocks are 6 years old-50k miles, tire about 30k/4 years old. I hear KYB’s are pretty stiff but don’t have any other reference as the last 4 cars I built I used them. My ride has seemed stiffer and more jarring on potholes lately. Front more so than rear. Buying new shocks as a Xmas present and new tires may be next purchase. In my experience old tires in L.A seem harder as they get older (ozone). Both front rims have bends on inner lips from potholes here.
Like I said this is a daily driver and I want a performance ride but more importantly need to smooth out the bad roads here. I do mostly city not freeway driving. I actually lost the whole accessory electrical buss once as the main feed separated from the buss connection (at fuse box) driving over the bumps on Franklin Ave. between LaBrea and Fairfax.
So that is why I think the inertia valve design in the Edelbrocks might be the answer. Looking at prices my choice is either Edelbrock or Bilstein. QA1's too much $$$.
Opinions? Anybody have Edelbrock shocks?
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Hazwoy] #566398
12/30/09 07:03 AM
12/30/09 07:03 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That southbound exit off Highland has those soft lumps, it's sort of high speed, everyone drives over the speed limit on it, and it's a soft radius turn. The stretch of road is good test of shocks though. Just driving around Hollywood today for business as a matter of fact (company van).
I bet the front shocks are toast. Lift of the car, extend the shock and look for leakage. I did that once with the cuda and the KYB immediately made a puddle of oil. Just drained out right there. On 60 mph freeway connector curves when you hit soft lump and cracks, does the car sort of wallow/yaw/hunt around a little bit? When my KYB's went bad it did that.
I've heard the E-brock shocks are stiff. Gmachinedart (Peter) has run them with 1" T-bars. Hopefully he will chime in.
The low profile front tires are contributing, but the are not rubber band category.
I'm thinking Bilstein or QA1. But if you were happy with the KYB's originally, they're a BIG price difference.
I've never bent a rim on any streets, but my car has steel rims. We have a Mustang GT in the family with 245/45 tire but those rims are cast aluminum.
What color is your Charger? Is it the dark blue one that Jack used to own?
Re: Bilstein/Edlebrock/QA1 shock decision [Re: autoxcuda] #566399
12/30/09 07:48 AM
12/30/09 07:48 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I think the KYB's are your biggest current negative, just changing them out will be an improvement, my , QA1 single adjustables.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: jcc] #566400
12/30/09 09:01 AM
12/30/09 09:01 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
either the eddies or the bilsteins will be a big improvement over the KYB's.
2017 Grand Cherokee Overland
Re: Bilstein/Edlebrock/QA1 shock decision [Re: jcc] #566401
12/30/09 09:13 AM
12/30/09 09:13 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I've got the E-Brock shocks on my 68 Barracuda and like them- firm but not harsh, .92 t-bars 1" sway bar up front 255/50-17s all around, no rear bar yet. If I were to go bigger with the t-bars I'd get the QA-1s according to Edlebrock the ones I have are about as stiff as they can control.
My car is a street car, but not a daily driver and I suspect that the shocks are going to be QA-1s down the line. The rear 'cause I'm planning on putting in the RMS Street Lynx.
After all that I'd recommend just saving the coin and getting the QA-1 single adjustables, they are re-buildable and will be able to deal with any future upgrades on your bigger car.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Hazwoy] #566402
12/30/09 02:58 PM
12/30/09 02:58 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
The stiffer the suspension is for performance handling the better the shocks need to be to control the suspension. I would go with Bilstein, Koni or QA1. Experience tells me you'll not regret the extra money spent. Shocks are the most important part of a performance suspension as they are designed to work with higher spring rates.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: autoxcuda] #566403
12/30/09 03:35 PM
12/30/09 03:35 PM
Los Angeles
Hazwoy Offline OP
Hazwoy  Offline OP
Los Angeles
Decision, decisions... Would be easy (QA1 best bet) except have to budget for dropped spindles, big front brakes, fuel tank repair, rebuild heater box, paint, exhaust with exhaust/heater box/tank needed RIGHT AWAY. Cost of items pretty important.
Here is my ride, AutoXCuda...
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Hazwoy] #566404
12/30/09 09:02 PM
12/30/09 09:02 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I'd spend the coin on shocks before the dropped spindles and big brakes.
Just get the 11.75" rotors and taller brake caliper mounts for brakes. Plenty of stopping power for a street car. Then get the RMS UCAs and adjustable strut rods. They will allow for plenty of adjustment for alignment.
I know about having to prioritise spending and it's less expensive to buy the good stuff the first time.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Skeptic] #566405
12/30/09 11:44 PM
12/30/09 11:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I agree on holding off on the spindles and big brakes. But I can always get good alignment with the stock UCA and stock strut rods. I'd do that when you do the dropped spindles.
BTW, what backspace are your front rims? The dropped spindle will only take "I think" 5 inches of backspace. I'll have to do a search on another site to find the guy that ran into the backspacing limit deal with the dropped spindles.
I can see why you could need the dropped spindles. The taller the tire gets, keeping the ride height the same, the closer the lower control arm gets to the frame.
This is how close my LCA is to the frame. I have no bumpstops. I only have 24.7" diameter tires though. Also note: my car has 10% stiffer spring rate and probably 400-500 lbs lighter car.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Lefty] #566406
12/31/09 01:26 AM
12/31/09 01:26 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I suspect you might be bending your rims because of the application, the AR rim, the 45 tire, hitting pot holes and your ride height. The dropped spindles may be needed, with all the above.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Hazwoy] #566407
12/31/09 06:33 AM
12/31/09 06:33 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
BILSTEIN's no question IMO
Re: Bilstein/Edlebrock/QA1 shock decision [Re: A12] #566408
12/31/09 07:13 AM
12/31/09 07:13 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used Koni's on my '68 convertible a-body and absolutley love them. I got them and some other suspension goodies through Firmfeel. Excellent customer service there as well.
The only thing I wish I would have added is the adjustable strut rods, as I only get just over 1 degree of positive caster with the stock strut rods and tubular upper control arms.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: Hazwoy] #566409
12/31/09 09:39 AM
12/31/09 09:39 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
With a '72, are the front shocks even available? I think '73 was the cut over, but I'm not positive. Checking availability may help make the choice for you.
FWIW, Varishock is another possible choice. Available in single or double adjustable and stroke lengths from 4.25 to over 22 inches with a variety of mounting tip optioins, they can put together a combination to fit almost any car.
Re: Bilstein/Edlebrock/QA1 shock decision [Re: TC@HP2] #566410
12/31/09 12:45 PM
12/31/09 12:45 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
72 B-body is just like an E-body. 73 is when they went to ISO K=members.
I've been trying to figure this out. Is a Varishock just a retagged QA1. They look awlful similar. Or do they use the same body with differernt guts??
Re: Bilstein/Edlebrock/QA1 shock decision [Re: jbc426] #566411
12/31/09 12:50 PM
12/31/09 12:50 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I'm really surprised you couldn't get more caster with the Firm Feel A-arms.
