'70 Challenger Shaker Hood Questions #566353
12/29/09 10:33 PM
12/29/09 10:33 PM
Milwaukee, WI
In_The_Pink Offline OP
Milwaukee, WI
1) What is the distance from the rear edge of the shaker trim ring to the rear edge of the hood on a '70 Challenger shaker hood, measured along the longitudinal centerline?
2) Is the central spine or rib on the shaker hood more pronounced than on a standard (flat) hood?
3) Were hood pins optional for '70 Challenger shaker hoods?
4) Are '70-'71 Dodge and Plymouth shaker scoops (the visible top piece which pokes through the hood) the same part?
TIA.
Re: '70 Challenger Shaker Hood Questions [Re: In_The_Pink] #566354
12/30/09 05:26 PM
12/30/09 05:26 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
1. I forget off the top of my head, I think it's 12.50" inches, but here is the front hood edge to drop down dimension for sure. This is an original hood, not a reproduction.
Re: '70 Challenger Shaker Hood Questions [Re: ScottSmith_Harms] #566355
12/30/09 05:28 PM
12/30/09 05:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2. No, the flat hood peakis identical to the shaker hood peak (as is all else). Here is the "Style" that was on 99.99% of production line Shaker Challengers, the flat front "DODGE" lettered hoods came at the very end of production and for a couple cases, did not come on production line cars, just over the counter.
Re: '70 Challenger Shaker Hood Questions [Re: ScottSmith_Harms] #566356
12/30/09 05:29 PM
12/30/09 05:29 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
3. Yes, hood pins were optional on Challengers, they were standard only on Cuda's
Re: '70 Challenger Shaker Hood Questions [Re: ScottSmith_Harms] #566357
12/30/09 05:31 PM
12/30/09 05:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
4. Yes, all under hood and bubble parts are the exact same parts with the sole exception of the shaker bubble emblems. The hood under structure piece welded into the under side of the hood was unique to Challenger, Cuda versions were different.
