Re: Whats a good 8-3/4???
[Re: Moparnut426]
#565517
12/29/09 01:01 AM
12/29/09 01:01 AM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
742-489-741 last
this is according to quicktree who is considered expert in the 8 3/4
i ran 10.0's at 3235 with a 489 case,spool and one billet cap/stock axles foot brake
my old man 10.90's with 489 case stock caps,spool and yucon axles foot brake
WAXER
[Re: DoctorDiff]
#565520
12/29/09 09:11 AM
12/29/09 09:11 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
One that looks like this ..................
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Cab_Burge]
#565523
12/29/09 11:06 AM
12/29/09 11:06 AM
BradH
The 742 is the one I consider the best...
Same here. Mine has MW steel caps on both bearings, plus a billet steel yoke, a PowerLock unit (no cone-type Sure-Grip units for me ) and a back brace on the housing.
[Re: Moparnut426]
#565527
12/29/09 07:28 PM
12/29/09 07:28 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
I would be more concerned about a back brace and billet caps to be honest, but my least favorite pig is the 741 case obviously. I've got a 489 with a crush sleeve eliminator kit in my Coupe.
CrAzYMoPaRGuY
[Re: jcc]
#565529
12/29/09 07:49 PM
12/29/09 07:49 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
A 489 case does NOT have a larger rear bearing than the 742 version. 742 pinions have a huge stress riser at the base of the front bearing, however. Pinion design doesn't seem to matter anyway, because the ring gear has proven to be the weak link, regardless. Check out this link for pinion comparisons: http://www.moparts.org/Tech/Archive/axle/1.html
[Re: DoctorDiff]
#565534
12/30/09 10:46 AM
12/30/09 10:46 AM
Posts: 5,894 Florida
Locomotion
Somewhere I have heard that one factor in the strength of the ring gear lies in the number of teeth on it. The less teeth, the bigger they are, thus stronger. I don't know if there are other 8 3/4" examples of basically the same ratio having different amounts of ring and pinion teeth. 742 case:Richmond 4.57 = 32-7 Moser 4.56 = 41-9 But there are other factors too, like metalurgy, quality control, etc. I just go with the better price. I am trying a set that has been cryo'ed and rem-finished by Jim Bailey. http://www.finishedracing.com/
[Re: Locomotion]
#565535
12/30/09 11:21 AM
12/30/09 11:21 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
742 case:
That's an interesting thought. But wouldn't more teeth spread the load out more?
