Re: 440 Cam [Re: BradH] #565502
01/01/10 02:07 PM
01/01/10 02:07 PM
Kirkland, Washington
Pacnorthcuda Offline
I'll also add that the Crower cams that THESHAKERPROJECT has in his cars don't experience the high-rpm lifter "crash" issues that some of the more mainstream cam companies' "extreme" hydraulics have a well-deserved reputation for.
What is this "high-rpm lifter crash" of which you speak?
Re: 440 Cam [Re: Pacnorthcuda] #565503
01/01/10 04:11 PM
01/01/10 04:11 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I'm just curious, how much does a 70 gtx weigh? I'm a big man:6 feet 2 inches and 330pds. Is that a hinderance to burning out? Be Honest fellas.
Re: 440 Cam [Re: roy2345] #565504
01/01/10 05:08 PM
01/01/10 05:08 PM
well, its better burn out than it is to rust but hey, at 330 pounds you might burn out before your time. You wanted honesty.
70gtx will probably trip the scales at about 3800.
Re: 440 Cam [Re: Pacnorthcuda] #565505
01/01/10 05:17 PM
01/01/10 05:17 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
ok i mean is the xtra weight hindering me to spin tires?
Re: 440 Cam [Re: roy2345] #565506
01/01/10 05:30 PM
01/01/10 05:30 PM
From a dead stop I'd say no, since the wheels have to get the weight moving, and more weight is harder to move.
From a roll it probably would be harder to break em loose with more weight though.
Not sure....
Re: 440 Cam [Re: Pacnorthcuda] #565507
01/01/10 08:30 PM
01/01/10 08:30 PM
scratchnfotraction Offline
turn a corner and gas it in low gear and hold it on the floor till it hits 4500-5000 rpms and shift it
if its got a sg it wont spin much as thats what they are for
if its a one wheel wonder it will smoke one turn around a left or right turn
try that and get back to us
nothing like a dirt road for spinning the tires either
I am about the same size and every thing I got will spin a tire around a corner for sure...I do it often too
Re: 440 Cam [Re: scratchnfotraction] #565508
01/01/10 09:00 PM
01/01/10 09:00 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
What is a sg? My linkage is somehow ferked up. I can only get it in PRND. No drive 1 or 2. The reason is long story. But I have a floor shifter and console to install so all that will be corrected. So only being able to put into regular drive hinders me being able to spin out?
Re: 440 Cam [Re: Pacnorthcuda] #565509
01/01/10 09:58 PM
01/01/10 09:58 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
It means that Comp Xtreme hydraulic cams have overly-aggressive closing ramps which limit their RPM potential to well below what smoother hydraulic profiles are capable of.
It's not just a "Mopar thing" either. I've seen SBC and Pontiac tests w/ those series of cams where the valve train starts to go bonkers anywhere from 5000 RPM on up.
Re: 440 Cam [Re: BradH] #565510
01/01/10 10:12 PM
01/01/10 10:12 PM
IA
landon1 Offline
landon1  Offline
IA
idk i can't verify rpms, since i don't have a tach, but my new motor makes power way higher in the rpm range than it did and with a 650 carb limiting it further...i think my XE268 is supposed to be good to 6200 RPMs, but with a basically stock rebuild, i doubt i'll ever go over 5-5500 RPM.
the XE lifters are supposed to be "ticky" also, which i don't notice either
'71 Satellite Sebring 440
Re: 440 Cam [Re: landon1] #565511
01/01/10 10:41 PM
01/01/10 10:41 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought it was the XE-HL cams that were supposed to be "ticky". My lunati voodoo 60303 is no louder at the engine that my stock cam was.
Re: 440 Cam [Re: roy2345] #565512
01/02/10 08:47 AM
01/02/10 08:47 AM
sg = suregrip in the rear differental
makes both wheels want to spin,which hinders showboating by smoking the tires
its for traction not burn outs,but it will do a burn out with both tires if in good condition and you have enuff engine to do it with
not sure on you shifter problem,but they did come with a 2nd/low gear lock out on the tranz in some cop cars
it bolted to the tranz pan rail to block the shift lever
you could remove it to get all the gears
dont sound like what you got but just in case it some thing to look for if its not getting 2nd and low gear
Re: 440 Cam [Re: scratchnfotraction] #565513
01/02/10 12:09 PM
01/02/10 12:09 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Ok..Thanks for input thus far. You guys are amazing! Mine has a modified slip posi. The guy did something inside to make it do that when xtra torque applied. However,440 BB still should burn out tires in a 3800 pd Satellite so I've been told.
Re: 440 Cam [Re: roy2345] #565514
01/02/10 12:36 PM
01/02/10 12:36 PM
IA
landon1 Offline
landon1  Offline
IA
definitely...the old worn out caved-in lifter smogger motor i rebuilt would do a one wheel strip 50' prior to the rebuild
Re: 440 Cam [Re: roy2345] #565515
01/02/10 12:41 PM
01/02/10 12:41 PM
never heard of a mod to make one slip with too much HP
a suregrip is a limeted slip unit already
cone type wear out and slip one tire more when over powerd
there are mods to tighten it up so it wont slip as much..milling the cones and adding springs/shims ect...
you need to check your rear axle to see what you do have and if its a suregrip or not
if its an 8 3/4 what chunk is it? 714-742-489???
they also have a suregrip that used clutches and the can be replaced when worn
dont know what he would have done,but to make one slip when over powerd is not something I would do if it was possiable
did he add a locker maybe?
