never heard of a mod to make one slip with too much HP
a suregrip is a limeted slip unit already
cone type wear out and slip one tire more when over powerd
there are mods to tighten it up so it wont slip as much..milling the cones and adding springs/shims ect...
you need to check your rear axle to see what you do have and if its a suregrip or not
if its an 8 3/4 what chunk is it? 714-742-489???
they also have a suregrip that used clutches and the can be replaced when worn
dont know what he would have done,but to make one slip when over powerd is not something I would do if it was possiable
did he add a locker maybe?
