Re: trust a torsion bar?
[Re: Supercuda]
#565471
12/30/09 01:48 AM
12/30/09 01:48 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
parallel to the bar is usually ok, perpendicular is what's bad. If you smooth and dress the nick, and it's not deep, it's usually ok.
However, if you can afford it, replacement is probably teh best bet.
Just think about where the T bar lives and all the road juck that's hit all the T bars over the years. How many have actually failed? Probably not many, I've had the adjuster bolts rip out, but never a T bar fail. FWIW.
Actually a thread came up a couple years ago about a torsion bar that had broken & about a dozen members had experianced failures.. FWIW one broke on my dads Chrysler back in 69 while it was sitting in the driveway...
[Re: Supercuda]
#565472
12/30/09 08:55 AM
12/30/09 08:55 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if it's not too deep and you sand the blemish smooth to eliminate the stress concentrator, you'll most likely be fine.
a torsion bar's peak stress is at the surface, so a surface blemish like a gouge will be the failure point.
[Re: GTXKen]
#565474
12/30/09 11:07 AM
12/30/09 11:07 AM
patrick
Grand Haven, MI
I have to say that the idea of sanding and painting the nicked torsion bar as a repair makes no sense at all. I can't see how simply removing the raised area and masking it is hoing to help. Sanding down the high point will not improve the strength of the bar. If the nick removed material what is sanding going to do?
it removes the stress riser. localized stress in a corner will be higher, to mathmatically infinite as the corner radius decreases to 0. the most graphic illustration I could find in a 2 minute search of the intertubes is page 7 of this:
http://www.utm.edu/departments/engin/lemaster/Machine%20Design/Lecture%2004.pdf
note how as the notch gets smoother and more gradual to the underlying material, the stress distribution becomes less concentrated, and the peak stress goes from 16 to 7.
granted, this is an axial pull, torsion is a slightly different beast, but the results are similar, as if you look at a local spot on a torsion bar, the stresses and loading is pretty much an axial pull.
now, the slightly smaller cross section in that area will very slightly reduce the effective spring rate and maximum load carry capacity of the t-bar....
[Re: patrick]
#565475
12/30/09 11:41 AM
12/30/09 11:41 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
Thanks Patrick, your explanation along with the illustration makes it much clearer. The painting is cosmetic but removing the burr reduces the stress. I'll take a look at my bar and reassess its condition.
[Re: GTXKen]
#565476
12/30/09 12:10 PM
12/30/09 12:10 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Probably 10 years ago now, when I was working as a mechanic, a newer Ford F-150 came in with one side sagging. It was in the middle of winter so we thought a shock had frozen or something.
We put it on the lift and sure enough, one of the bars had broken. We left it inside over night and when we went to drive it out the next morning, we realized that the whole front end was sagging. We raised it back up and the other bar had broken overnight.
