Fluxuating oil pressure #565080
12/28/09 04:51 PM
12/28/09 04:51 PM
N.E.Ohio
P
Polarabill Offline OP
P
N.E.Ohio
I have a fairly fresh rebuilt 73 440(under 2000miles on it). At times when driving at 55-65 mph the oil pressure will slowly start dropping. it will go from 60 to almost 0.when I let off the gas for a moment it starts climbing again.I'm thinking I need a breather in the valve covers since there are none. It does have a pcv vent to the carb.Do you think I'm on the right track or is there something else I need to check?
This would be so much easier if I knew what I was doing...
Re: Fluxuating oil pressure [Re: Polarabill] #565081
12/28/09 04:55 PM
12/28/09 04:55 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
How much oil capacity ? .. grade of oil? .. oil temp?
Re: Fluxuating oil pressure [Re: Polarabill] #565082
12/28/09 04:55 PM
12/28/09 04:55 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I don't know if it will fix the problem but you need to vent the crank case. If you are drawing air out through the PVC valve, and it can't be replaced you will cause vacuum in the case. Usually pvc on one side and vent on the other.
Re: Fluxuating oil pressure [Re: dOc !] #565083
12/28/09 05:02 PM
12/28/09 05:02 PM
N.E.Ohio
P
P
N.E.Ohio
It's a 5 quart system running 10w30 Rotella oil. No oil temp gauge.
Re: Fluxuating oil pressure [Re: Polarabill] #565084
12/28/09 05:17 PM
12/28/09 05:17 PM
Florida STAYcation
Florida STAYcation
Is the oil cold when it does this ?
Re: Fluxuating oil pressure [Re: dOc !] #565085
12/28/09 05:19 PM
12/28/09 05:19 PM
N.E.Ohio
P
P
N.E.Ohio
No, only after it is up to operating temp.
Re: Fluxuating oil pressure [Re: Polarabill] #565086
12/28/09 05:29 PM
12/28/09 05:29 PM
Florida STAYcation
Florida STAYcation
What kind of gauge is telling you the oil pressure ?
Re: Fluxuating oil pressure [Re: dOc !] #565087
12/28/09 05:46 PM
12/28/09 05:46 PM
N.E.Ohio
P
P
N.E.Ohio
Stock,factory 64 Polara gauge
Re: Fluxuating oil pressure [Re: Polarabill] #565088
12/28/09 05:56 PM
12/28/09 05:56 PM
Florida STAYcation
Florida STAYcation
If it is going down to almost ZERO(and is going almost 60 mph) ...and the engine is not making any strange noises ....
I say that the gauge is defective OR the sending unit is.
Re: Fluxuating oil pressure [Re: dOc !] #565089
12/28/09 06:01 PM
12/28/09 06:01 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Check your pressure with a mechanical gauge.
A BB chev, just rebuilt in a pickup, was over at a mechanics house.. It had a horrible squeal that no one could diagnose.. Mechanic was just getting ready to pull the pan thinking the engine bearings were going out or were installed wrong.. Yes, it was making a horrible sound... I listened to it, and looked at it, then reached in and took out the oil "plug" in the valve cover.. No more squeal..
The pcv was pulling vacuum and the "plug" on the other valve cover was not letting in any air.. The whole engine was under vacuum and everywhere the engine could leak air it was.
God I felt good that day... A hero....
Re: Fluxuating oil pressure [Re: dOc !] #565090
12/28/09 06:07 PM
12/28/09 06:07 PM
N.E.Ohio
P
P
N.E.Ohio
Thanks for the info.I think I'll replace the sending unit and mount a temporary gauge and see what happens.
Re: Fluxuating oil pressure [Re: Polarabill] #565091
12/28/09 07:13 PM
12/28/09 07:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
But vent the one valve cover first. negative pressure in the crank case will cause O oil pressure
Re: Fluxuating oil pressure [Re: Dodgem] #565092
12/29/09 11:43 AM
12/29/09 11:43 AM
N.E.Ohio
P
P
N.E.Ohio
Will do.
Re: Fluxuating oil pressure [Re: Polarabill] #565093
12/31/09 09:36 AM
12/31/09 09:36 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well?
Re: Fluxuating oil pressure [Re: Dodgem] #565094
12/31/09 10:23 AM
12/31/09 10:23 AM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
Fram oil filter? Could be colapsing inside.
Re: Fluxuating oil pressure [Re: Polarabill] #565095
12/31/09 10:50 AM
12/31/09 10:50 AM
I would take off the oil pump regulator plug & give the plunger/spring a good visual or maybe sub in another pump (check clearances/clean it 1st). You would want a breather on one valve cover and the pcv to the carb base on the other valve cover. EDIT As said gauge & sending unit 1st
