torsion bar boots and hood springs #564674
12/28/09 12:38 PM
12/28/09 12:38 PM
Raleigh, NC
j.mcconnell Offline OP
Raleigh, NC
I'm rebuilding the front end on my 73 Duster and need the seals/boots for the torsion bars. I saw the P/N in the archives but that said b-body. whats the p/n for my a-body.
also how can I take off the hood springs? fenders are off so access is good but i dont want that thing uncoiling on me if it can.
thanks
Re: torsion bar boots and hood springs [Re: j.mcconnell] #564675
12/28/09 12:42 PM
12/28/09 12:42 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
http://chucker54.stores.yahoo.net/torbarhar.html
$36 for the boots at Mancini and fit A,B, and E's...
On the springs, you have pry off those retainers (from the stud on the body) and just pull the springs/hinge off...it won't spring all out at you.
Re: torsion bar boots and hood springs [Re: j.mcconnell] #564676
12/28/09 12:45 PM
12/28/09 12:45 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Same part number for a-body t-bar boots.
Pry/pull the little circle clip off of the two pegs that hold the hood hinge, the spring won't come off unless you try to pry just the spring.
Re: torsion bar boots and hood springs [Re: j.mcconnell] #564677
12/28/09 01:35 PM
12/28/09 01:35 PM
Raleigh, NC
Raleigh, NC
i swear i couldnt find them on mancini an hour ago (even with a picture on the main page), oh well got them coming to the local dealer.
so can you separate the spring from the hinge or not? will be adding a bolt on fiberglass hood and was just going to run it with no springs.
thanks again
Re: torsion bar boots and hood springs [Re: j.mcconnell] #564678
12/30/09 12:41 PM
12/30/09 12:41 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
You can separate the spring from the hinge. It is swedged on the middle peg, so you may have to grind the middle peg a little bit to get the spring to slide off.
Re: torsion bar boots and hood springs [Re: j.mcconnell] #564679
12/30/09 06:50 PM
12/30/09 06:50 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
so can you separate the spring from the hinge or not? will be adding a bolt on fiberglass hood and was just going to run it with no springs. thanks again
A prop rod sucks. Replace the stock springs with low tension ones for that glass hood.
