Street Car undercarriages???? #563699
12/27/09 02:20 AM
12/27/09 02:20 AM
Boise, Idaho, U.S.A.
tims69belvedere Offline OP
I am wondering what you guys have done to the undercarriages of your car, for everyday or regular drivers. I have replaced my floors and want to do a quality job with my undercarriage for keeping rust away and protecting it. I am curious as to if you guys use undercoating, bedliner, or what anyone has used. Any thoughts are appreciated
Re: Street Car undercarriages???? [Re: tims69belvedere] #563700
12/27/09 02:25 AM
12/27/09 02:25 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
First seal it with etching primer & paint... Properly applied paint is very effective at preventing rust... After paint if you want to use undercoating to prevent rock chips & other damage to the paint thats fine...
Re: Street Car undercarriages???? [Re: 1_WILD_RT] #563701
12/27/09 07:31 AM
12/27/09 07:31 AM
IN
ahy Offline
ahy  Offline
IN
Agree good paint first. Etching primer to start if the steel is clean/bright. If it isn't perfectly rust free, use Red Rustoleum or Eastwood "Rust Encapsulator" primer first then a quality paint. I like to seal the seams after priming.
Re: Street Car undercarriages???? [Re: tims69belvedere] #563702
12/27/09 09:51 AM
12/27/09 09:51 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
First grease and wax remover to get rid of all the grease and finger prints. Then a lite sand blasting, then etch primer, then epoxy primer and then color. It'll out last any factory finish without under coating. IMO
Re: Street Car undercarriages???? [Re: Challenger 1] #563703
12/27/09 10:24 AM
12/27/09 10:24 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've found that a leaky drain plug on the oil pan can make a very nice misting/coating of oil under the entire car, and is a very good rust preventer!
it's just not very pretty!
**Photobucket sucks**
Re: Street Car undercarriages???? [Re: 70Cuda383] #563704
12/27/09 02:42 PM
12/27/09 02:42 PM
Thanks for the input guys
Re: Street Car undercarriages???? [Re: tims69belvedere] #563705
12/27/09 04:16 PM
12/27/09 04:16 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
When I had my Challenger I used that oil based stuff..Zero Rust I think, it was black, dried kinda semi glossy..cleaned off really well and just made for a clean look over, you can always paint color of it if you like.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Street Car undercarriages???? [Re: MonGoo$e] #563706
01/26/10 01:01 PM
01/26/10 01:01 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Is there anything that looks like the factory undercoating? I replaced about 70% of my chargers' underside and need to protect the new stuff but am not sure if I want to scrape off the factory stuff and paint or make the new stuff match the undercoated/old stuff?
Re: Street Car undercarriages???? [Re: challenger70] #563707
01/26/10 01:38 PM
01/26/10 01:38 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
On mine I just left it bare, with some surface rust exposed here and there underneath. Really on a summer-only car it doesn't get any worse over time. However I have been thinking of pressure washing it underneath, cleaning it up as best I can and hitting it with some primer then undercoating just to seal it up and make it look better.
I have found the Napa brand undercoating applied with a shutz gun gives a nice finish. I have used the aerosol bedliner spray on the top side of floors under the rug there I wanted it to dry harder than undercoating does.
Re: Street Car undercarriages???? [Re: challenger70] #563708
01/26/10 03:05 PM
01/26/10 03:05 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Resto Rick's undercoating is as close as you can get to the factory undercoating as far as texture and appearance. It also sets up nice and hard, unlike most other products.
Re: Street Car undercarriages???? [Re: Neil] #563709
01/26/10 05:33 PM
01/26/10 05:33 PM
Berwyn, IL
Berwyn, IL
Do you happen to know what prep is involved? I have such pristine floors now I hate to cover it up with undercoating, but it like my other car, will get driven a lot and hate to see it rust and keeping paint clean under there seems like an impossible task driving the car regularly. I replaced the full floor, footwells, torsion bar mounts, rear frame rails, full trunk, inner/outer wheelhouses and want to protect it as I won't be doing that again.
Re: Street Car undercarriages???? [Re: challenger70] #563710
01/26/10 07:45 PM
01/26/10 07:45 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
... 2 part primer, overspray with body color...rust check/crown or whatever clear undercoat you like...it will outlast you..
...now if it's a show car that oil probably won't be too welcome.
Re: Street Car undercarriages???? [Re: can.al] #563711
01/26/10 08:40 PM
01/26/10 08:40 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
i overrestored. painted bottom in single stage urethene. has lasted 6 years, but that is weekend driving. I did undercoat whereever rocks hit, espicially in wheelwells.
It washes up and still looks new!
Re: Street Car undercarriages???? [Re: hemibeep] #563712
01/26/10 11:58 PM
01/26/10 11:58 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I used Resto Rick's undercoat and I thought it was fantastic. You can apply it light or heavy to your liking. With a little practice, you can achieve a "clean" or OEM (nasty) look. I recommend 2 cans at least if you are doing an entire under body. It sucks to run out and have to clean up twice... stuff is pretty messy. Get a Shutz gun.
Re: Street Car undercarriages???? [Re: tims69belvedere] #563713
01/27/10 02:00 AM
01/27/10 02:00 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
When I restored my 69 Bee I painted the undercarriage the same as the rest of the car. Twenty years and thirty six thousand miles later it still looks good. I clean the undercarriage a couple time a year. I put the car on jack stands grab a good spray cleaner, a hand full of clean rags and wipe it down.
Re: Street Car undercarriages???? [Re: Dabee] #563714
01/27/10 02:09 PM
01/27/10 02:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I drive my 63 alot in the warmer weather. I put front floor pans in it and then just sealled them. I cleaned off all the loose undercoating and then painted the underneath with rustolium gloss black. I like the gloss black as it is easier to clean off if it gets dirty underneath from driving alot. If you scroll down on the link you can see the underneath on my 63. Ron
http://www.1962to1965mopar.ornocar.com/mmo82008.html
Re: Street Car undercarriages???? [Re: 383man] #563715
01/27/10 03:22 PM
01/27/10 03:22 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I used POR 15 on my 70 cuda
I held up incredibly well. I have used POR 15 recently but did not have the same good results, (came off in strips) I would not likely use it again. I think it has changed formulas
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Street Car undercarriages???? [Re: Kam*Kuda] #563716
01/27/10 03:25 PM
01/27/10 03:25 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I used Zero Rust on the Road Runner Worked well but I have not driven the car yet to say how it holds up
1654.5 Mustang
1955 Land Rover
Re: Street Car undercarriages???? [Re: 383man] #563717
01/27/10 03:32 PM
01/27/10 03:32 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I just spent about 30 hours removing the original undercoating off my car. The undercoating did its job, my floors look like new. I am waiting for the weather to break so I can finally paint it. I picked up a POR15 kit. I went with the semi gloss finish. I cant wait to finish up this project. I never thought that taking undercoating was going to be such a big job.
Re: Street Car undercarriages???? [Re: Kam*Kuda] #563718
01/27/10 03:34 PM
01/27/10 03:34 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Wow! That looks great! I hope my car comes out like yours.
