Re: milky dipstick -318
[Re: Mr71Bee]
#563550
12/27/09 11:49 PM
12/27/09 11:49 PM
Posts: 13,621 md
mopars4ever
md
why would oil type/brand matter?
Because in my past experience of using Quaker State oil I had a similar problem and I switched brands and I never had the problem again. I was curious to see what brand he used.
[Re: Mr71Bee]
#563552
12/28/09 07:58 AM
12/28/09 07:58 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
start simple:
This is the point. If you aren't loosing coolant - you don't have a leak. Also if there was a leak the oil level would increase and coolant would turn the oil milky right away. Condensation will also turn the oil milky after a period of time but not near as quick. Remember to that ice cold the coolant level will look to be somewhat low in the radiator, after it is warm it will expand somewhat.
[Re: chargers777]
#563553
12/28/09 08:16 AM
12/28/09 08:16 AM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
we have been driving it to work-25 miles one way.
Honestly ...25 miles is not going to heat-up the oil enough to "burn off" that condensation.
This is something you are just going to have to live-with.
[Re: mopars4ever]
#563555
12/28/09 10:02 AM
12/28/09 10:02 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
![](/ubbthreads/images/graemlins/iagree.gif) Yea my milk problem was much worse with qwaker state than any other oil!!
[Re: RodStRace]
#563557
12/28/09 01:35 PM
12/28/09 01:35 PM
MoparforLife
Upper Midwest
You can install a warmer thermostat to help too. My small block was happier with a 195 than a 160...
They all will be. better lubrication too.
[Re: MoparforLife]
#563558
01/03/10 05:58 AM
01/03/10 05:58 AM
Posts: 102 Virginia
MACDiesel
Virginia
I saw the same thing this morning when I checked the oil on my 440. I ended up canceling my day of cruising because I didn't want to risk running it without doing a compression check. We live in Hawaii and don't see temps below 70 in the day that often. So all my buddies here are freaking out because we don't see that too often. However, we recently moved to the much higher central Oahu where its always 10-15 degrees cooler than the rest of the island. At night and early morning the temps get down to low 50s. I know its only 10-15 degrees but the humidity never leaves 80-90%. So I guess this makes sense. The car hasn't seen temps this "cold" since its been on island.
I probably just pissed a lot of people off, talking about how "cold" it gets on Oahu.... my bad. Hey at least most of you mainland guys have a track to run on.
-1967 Belvedere II 440/4speed
[Re: MACDiesel]
#563559
01/03/10 08:40 AM
01/03/10 08:40 AM
MoparforLife
Upper Midwest
I can't believe this. My God it is that time of the year. Even in Hawaii you are going to have a certain amount of condensation. There is even condensation in the desert to a certain degree. It is a natural combustion byproduct in an internal combustion engine. Yesterday there was an actual ice build up from one stop light to the next from water running running out of the exhaust at -20 degrees. I have an ice build up on the quarter panel of the truck from a hundred and twenty mile trip in that weather. You won't find anything wrong other than short drives not burning off the condensation. Blown head gaskets are not that common. Coolant leaks do happen periodically but a great majority are external when they do happen. The colder the weather the longer it takes. Just because the temp gauge reads normal don't mean that the engine is completely warm or for long enough. ![](/ubbthreads/images/graemlins/violin.gif)
[Re: MoparforLife]
#563560
01/03/10 03:19 PM
01/03/10 03:19 PM
Posts: 102 Virginia
MACDiesel
Virginia
I want to put in an oil temp guage but I'm not sure which temp range to get. There are some that peak at 180 degrees and some that start at 180. What do you think?
