Re: Group discount on WIX Filters for Moparts members
[Re: Rug_Trucker]
#56334
04/20/08 12:48 PM
04/20/08 12:48 PM
Posts: 22 Canada
slantsixdan
Canada
I have a long stand pipe on my 198 slant. Will the long stand pipe work in my application?
I'm not quite sure what you're asking. If you're asking whether the #51806 internal-standpipe filter will work in conjunction with the tall pump-mounted standpipe on a slant-6, the answer is yes, though the pump-mounted standpipes, by their design, introduce a considerable restriction to oil flow. If you're going to use the #51806 filter with inbuilt standpipe, the optimal plan is to replace the pump-mounted standpipe with an ordinary low straight-through fitting such as comes with all new oil pumps.
You can't use the short or super-short filters with the tall standpipe.
Also the 2 quart version work on a slant?
Yep, as long as there's nothing in the way. It's a tight fit in narrow engine compartments (e.g. '60-'62 A-bodies, especially '62 w/inner fender mounted horns) but it does fit.
[Re: slantsixdan]
#56335
04/20/08 05:45 PM
04/20/08 05:45 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Thanks Dan a cheap way to increase oil capacity!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: PHJ426]
#56339
04/23/08 08:19 AM
04/23/08 08:19 AM
Posts: 10 New York
FilterGuy
New York
I ordered mine a week ago. Im thinking they got slammed with alot of orders and shipping is going to be longer than 6T6's 5 day turnaround.
Thanks for the group purchase !!!!!!!!!!!!!
Hi, this is Ryan from Filter 1. We did get quite a few more orders than we usually get for a few part numbers This normally wouldn't have affected us as our minimum stock is 168 for 51515, 42 for 51068, 48 for 51515R, etc... However this is the busy season for filters and our stock orders from Wix have been irregular at best, so your order did not ship until monday. I checked UPS and it is out for delivery today though, so expect it soon!
Now that we can adjust our minimums for the moparts crew, each order placed before 1 should ship same day. If you guys have any questions, feel free to email me, send me a PM or call.
Thanks, we really appreciate the business!
[Re: PHJ426]
#56341
04/24/08 11:14 AM
04/24/08 11:14 AM
#56342
04/25/08 09:13 AM
04/25/08 09:13 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I haven't visited this post in a while, sorry guys, but this group discount is permanent. The more we buy as a group the better discount we will get. But the prices I gave in the original post will be our base, they shouldn't ever get higher than that unless WIX push a price increase. But as long as we keep ordering like we are I don't think we will every have to worry about that.
Thanks Ryan for working with me to set this up and coming over to say Hi and help us with some questions.
I just got off the phone with Ryan and they are working with Wix to get us even better prices as it looks like we are going to reach the next level of discounts so keep those orders coming guys and again, I'm not getting anything out of this other than the discounts like you guys are taking advantage of.
Here is an updated Part # and Price list:
#51068 $3.59 shorter/stubby version of the 51515
#51515 $3.48 normal/standard Big or Small block 1qt oil filter, street version filters to about 20 microns, and has a bypass
#51515R $6.40 Race Filter, full flow race filter--no bypass, filters to about 60 micons, very high burst pressure
#51806: $5.94 A heavy-duty 51515 with a built-in standpipe to keep the filter positively full of oil after shutdown in base-down mounting situations (slant-6, for example). These also greatly reduce oil spillage when removing a base-down filter at oil change time, see here and here for more info
#51773: $5.06 An extra-long 51515 if you want your filter to hold two quarts of oil and have the space for it
#51076: $4.73 Heavy-duty replacement filter element for factory optional taxi/fleet/police replaceable-cartridge oil filter
#51085: $3.82 "Super Shorty" Mopar oil filter, 3.79" tall (the 51068 is 4.338" tall, the 51515 and 51806 are 5.18" tall, and the 51773 is just barely shy of 7" tall)
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#56345
05/10/08 02:15 AM
05/10/08 02:15 AM
Rug_Trucker
I am interested in getting some for the 93 Cummins, biggies for the slant, guess they would fit my 360's?
[Re: Rug_Trucker]
#56346
05/10/08 02:34 PM
05/10/08 02:34 PM
Posts: 902 Bellevue, WA
Blackwidow69
Ring Knocker
Ring Knocker
Bellevue, WA
Just got my big box of filters as well. Got air filters and oil filters for all the cars and truck and saved a bunch. Thanks for setting this up Wade.
1969 Ply Roadrunner, 383 4-speed on street tires.
3,830 lbs race weight.
Best 1/4: 13.1 @ 106.83
440 & overdrive 4 speed going in.
2005 Power Wagon 35X12.5 KM2's
[Re: moparman383]
#56349
05/30/08 06:10 PM
05/30/08 06:10 PM
Posts: 1,021 Chesapeake Va
BobK
Chesapeake Va
I just received my second order yesterday. These guys are right fast! Now I have 1 more order to go, and my fleet will all have filters!
1964 Plymouth Fury x 2 1964 Plymouth Sport Fury
[Re: BobK]
#56350
06/05/08 11:10 AM
06/05/08 11:10 AM
Posts: 6,363 Aurora, Oh.
max_maniac
Aurora, Oh.
How fast? I placed an order on 5/9/08 and have not received it yet. Guess I better call them
[Re: max_maniac]
#56351
06/05/08 12:10 PM
06/05/08 12:10 PM
BobK
Chesapeake Va
Maybe the filters you ordered are back ordered. Both of my orders were filled in a week or less.
[Re: jughed]
#56353
06/08/08 09:47 PM
06/08/08 09:47 PM
Posts: 4,408 Madison Wi
NTOLERANCE
Madison Wi
NAPAs web site shows the 1515R with a bypass valve.........
Is the NAPA filter different???
Thought they were the same?
