advice on tires, rear suspension and springs? #563317
12/26/09 04:29 PM
12/26/09 04:29 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
1)I need some advice on which tires to use on drag race 2700lbs car?
28x10.5 ??
Goodyear?
hoosier?
M/t?
2)
which one will be better a ladder bar or 4link???
103" wheldbase, I'll try 50% weigth front and rear.
500 to 700hp on motor, no aders.
3)
what springs pressure to use? front and rear coil overs.
Tks in advance.
Re: advice on tires, rear suspension and springs? [Re: v8punch] #563318
12/26/09 05:06 PM
12/26/09 05:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
28x10.5 ??
Goodyear?
hoosier?
M/t?
2)
3)
Tks in advance.
I like the Hoosiers myself but I have run MT also
along with Phoenix... never ran GY
4-link is the best but it also takes a little more
to get it adjusted right
Springs... that will matter on the final weight
distribution and the length of the shocks... mine
uses 85# springs(85# per inch) but the car is 2400
with me
Re: advice on tires, rear suspension and springs? [Re: MR_P_BODY] #563319
12/26/09 05:24 PM
12/26/09 05:24 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
I like MT's I've used the 28x10.5's and the 28x11.5's both worked real good in the hot and the cold they don't take much of a burnout either... My tires sidewall wears out before I run out of hole
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: advice on tires, rear suspension and springs? [Re: StripeHOG] #563320
12/26/09 05:39 PM
12/26/09 05:39 PM
M/T slicks here.
i personally think hoosiers are a cheap walmart style slick.all 3 cars run M/T's now.
40-45 passes and they are done.sidewalls completely gone away.
Re: advice on tires, rear suspension and springs? [Re: v8punch] #563321
12/27/09 01:27 AM
12/27/09 01:27 AM
Put the tallest and widest tire you can fit on the car, I'm sure the traction down there is marginal most of the time, epsecially on the streets, maybe not I would start out with a bias ply tire and sort the car out and then, maybe, try a radial slick of the same size. I have found that the radial tires will be faster and quicker here in the U.S. on good tracks, the bias ply tires work better(easier to drive the car off of the starting line ) on the marginal to bad tracks up here As far as rear suspensions I like use ladder bars, I have not yet owned a car with a four link set up in it, I have help a freind who had one on a 1963 Chevy 11 shoe box with a 586 HP SB 383 SB stroker motor with big (15x33x15) rear tires, we never did get it where it work excellent As far as the three ladder bar cars I have owned and driven, none of them work bad
Re: advice on tires, rear suspension and springs? [Re: StripeHOG] #563322
12/27/09 05:31 PM
12/27/09 05:31 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I agree with StripeHog, Sticky Mickeys, small burn out, good hook, just don't last long. I'm not sure why sidewalls wear out first?
Brian
Re: advice on tires, rear suspension and springs? [Re: '72CudaRacer] #563323
12/27/09 05:33 PM
12/27/09 05:33 PM
Mooresburg, Tn
Mooresburg, Tn
Could this be the problem?
Re: advice on tires, rear suspension and springs? [Re: '72CudaRacer] #563324
12/27/09 06:02 PM
12/27/09 06:02 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I use Hoosier, have used Phonix, find them to wear out quick, but they work great on the street.
