Desparately need help kickdown problems on a 73 #560258
12/22/09 09:12 PM
12/22/09 09:12 PM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
I believe I've got all the correct parts to hookup my kickdown linkage on my 73 Charger 400-4bbl 727 automatic column shift. There isn't many good illustrations available but from what I can tell in the few illustrations I do have is that I'm missing the clip that holds the kickdown rod to the transmission lever because there is no hole in the rod for a pin. Anyone who has probably a 71-76 with a big block and column shift it should have this clip. Does anyone have any photos so I can at least see how it mounts and what exactly I'm going to have to hunt for?
Re: Desparately need help kickdown problems on a 73 [Re: wh23g3g] #560259
07/09/10 09:47 PM
07/09/10 09:47 PM
Springfield VA
GTXOnsfri Offline
GTXOnsfri  Offline
Springfield VA
Sorry I don't know about a 73, but I guess it's probably the same as the 68. Here's a photo of the clip at the end.
Re: Desparately need help kickdown problems on a 73 [Re: wh23g3g] #560260
07/09/10 10:01 PM
07/09/10 10:01 PM
Springfield VA
GTXOnsfri Offline
GTXOnsfri  Offline
Springfield VA
Here is the diagram from the 68. You can see the clip at the end.
Re: Desparately need help kickdown problems on a 73 [Re: GTXOnsfri] #560261
07/10/10 12:06 AM
07/10/10 12:06 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
You can get that type of clip at any chain parts store, they have assortment packs and are what to use.
Couldn't tell you if they're oe acceptable though.
I can't afford this. mark
Re: Desparately need help kickdown problems on a 73 [Re: a12superbee] #560262
07/11/10 12:16 AM
07/11/10 12:16 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
it was like the one i needed like in the picture except it has to be for a fatter rod...had to buy a used rod that had the clip from a swap meet..
