73-74 E body trunk weather strip #559662
12/21/09 08:26 PM
12/21/09 08:26 PM
Colorado
denfireguy Offline OP
Colorado
Anyone know how this weather strip is attached? This is a Soft Seal that is supposed to be correct for E bodies made after 1/1972. Does the rib mount down or up? Is the flat part (the one on the left of the picture) supposed to go flush to the trunk lip?
The shop manual only shows the weather strip from the early E bodies in its illustration (the tail lamps are the 71 version in the manual).
Or should I just get an early weather strip and put it in the way the book says to?
Thanks for your help,
Craig
Re: 73-74 E body trunk weather strip [Re: denfireguy] #559663
12/22/09 08:05 AM
12/22/09 08:05 AM
NJ
440challenger Offline
NJ
Just had this same problem last night! On my 73 Cuda. The flat part goes down....(I called metro to verify) , I fit it and glued it on. Went to shut the lid ... No way was it fitting!!!
Bulged the lid up and put a huge amount of pressure. I ended up having to rip it off, and i just ordered a eariler style from columbia parts on ebay.
What i dont under stand is what is so different abount a late 73-74 trunk lid/ gutter that makes that huge weatherstrip even work?
Re: 73-74 E body trunk weather strip [Re: 440challenger] #559664
12/22/09 09:17 AM
12/22/09 09:17 AM
Colorado
Colorado
I am with you. There is no physical difference that I know of. I put it on the same way initially and pulled it off for the same reason. I am going to go with the early stuff too. Snoopy posted the factory drawings on how to install it and I think that is the way to go. My factory manual agrees with Snoopy but he had much more detail.
While my resto is not totally correct, I wanted it as close as possible within reasonable dollars. I just want a dry trunk.
Thanks for your reply
Craig
Re: 73-74 E body trunk weather strip [Re: denfireguy] #559665
12/22/09 09:23 AM
12/22/09 09:23 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Maybe what happened is they realized the earlier style sucked and leaked over time, so they went bigger thinking it would be better?
**Photobucket sucks**
Re: 73-74 E body trunk weather strip [Re: 70Cuda383] #559666
12/22/09 09:34 AM
12/22/09 09:34 AM
Colorado
Colorado
That is quite possible but the aftermarket stuff went off the deep end. It is way too thick to work. There is only so much baloney you can stuff before the sandwich leaks.
Craig
Re: 73-74 E body trunk weather strip [Re: denfireguy] #559667
12/22/09 09:47 AM
12/22/09 09:47 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Here's an original 74 for reference...
someone makes them in this profile, just can't remember who! Tom @ RT Specialties likely has them.
Rick
Re: 73-74 E body trunk weather strip [Re: RestoRick] #559668
12/22/09 10:11 AM
12/22/09 10:11 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Rick
is that the actual shape? or is your thumb deforming it as you pinch it to hold it?
Re: 73-74 E body trunk weather strip [Re: 70Cuda383] #559669
12/22/09 11:04 AM
12/22/09 11:04 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think I got mine from Tom at R/T. The bodyshop wanted all the weatherstripping on the car before they did any of the panel alignment. I never heard that they had a problem with the seals holding the panels out of possition. All I know is that the trunk, door and hood seals/bumpers were in place when the bodywork was being done.
Re: 73-74 E body trunk weather strip [Re: burdar] #559670
12/22/09 05:13 PM
12/22/09 05:13 PM
Colorado
Colorado
They told me the same thing. I have mine back and they said bring it back and they will do the final tweaks to put everything in place.
Craig
Re: 73-74 E body trunk weather strip [Re: RestoRick] #559671
12/22/09 05:16 PM
12/22/09 05:16 PM
Colorado
Colorado
Rick
Thanks. I will get in touch with him. The originals were so mishapen I could not rule out the Soft Seals but was skeptical.
Craig
Re: 73-74 E body trunk weather strip [Re: 70Cuda383] #559672
12/22/09 05:28 PM
12/22/09 05:28 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Rick
Well it's not my thumb.. , but the sample I have is that shape without being squeezed. Between the flap shape and hollow core, it compresses pretty easily.
Rick
Re: 73-74 E body trunk weather strip [Re: RestoRick] #559673
12/22/09 05:31 PM
12/22/09 05:31 PM
Colorado
Colorado
Thanks everyone, just ordered it from R/T Specialties.
Craig
