Anyone try Dupli-Color Paint Shop Lacquer ?
#557937
12/19/09 03:14 PM
12/19/09 03:14 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
I saw this paint at O'Reileys and for about $50 I can repaint the front valance on the Dakota. Anyone try it...this is a worktruck. www.duplicolor.com
Still looking for LM29H1B415501, '71 Demon 340
Re: Anyone try Dupli-Color Paint Shop Enamel ?
[Re: PAULS_340]
#557939
12/19/09 05:53 PM
12/19/09 05:53 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
used it on a hood scoop a last year. used their primer, artic white and clear. the primer was suppose to be gray but when mixed it was white. sprays really easily decided to change the color of the car so I repainted it with a good paint system. So I can not say how it holds up. Rob
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: PAULS_340]
#557943
12/19/09 10:37 PM
12/19/09 10:37 PM
Posts: 172 Mooresville, NC
Intense RT Dan
Mooresville, NC
You can go to a ppg or automotive paint store and they will mix you enough to use in this disposable spray device. The guy at a store I used for years said it works pretty good. I can't recall if the propellant was separate or not. It wasn't expensive and they should be able to match the paint perfectly with those paint spectrometer or whatever it's called. Oh, that would be a urethane paint too, I believe.
[Re: DaytonaTurbo]
#557945
12/20/09 03:34 AM
12/20/09 03:34 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Only thing I really heard about it is because it's an uncatalyzed laquer, as in no hardener, it will be susceptable to being damaged by chemicals. Someone explained it to the effect of when enamel paint dries, something about the make up of it causes it to not be able to be reliquified by solvent, where this laquer(with no available hardener) will. Someone claimed they used it and a gas spill messed with the finish. This is just what I read on another forum, no first hand experience.
Laquer in general never had a catalist option, so yes it can be removed, softened or liquified with thinner or gas..but it will dry and return to it's orginal state if you dont mess with it.. There have been hundreds of millions of cars painted with Laquer.. If you spill gas on your cured laquer finish, simply let it dry for a couple of days and wax or buff it ... Here is my 68 Charger R/T painted in Laquer/ clear in 1992, and yes I have accidentally spilled gas on the paint when the nozzle didnt shut off quick enough..
