How many N code BH27 Barracudas built
#55585
04/02/08 11:50 PM
04/02/08 11:50 PM
Posts: 500 NoVa
ebodyseast
NoVa
My 1970 Barracuda 383 convertible, BH27NOB, is 1 of 36 383 four barrel cars built for '70, according to several sources.
There were 3 different 383's available in '70 for Barracudas. Two were L code (5th digit in VIN) - the 290hp 2bbl and the 330hp 4bbl. The other, the N code, 383HP 335hp engine that was standard in all 1970 'Cudas.
The total production number of 36 has lumped/combined these two very different 4bbl versions together - the L code and the N code. The difference is the 440 cam & color coded springs installed that adds the 5hp. I have only seen one other BH27N in past 19 years of research - on the net awaiting a resto. I have seen maybe 3 BH23 & 4 or 5 BP23 Gran Coupe HT's that were N code 383's - so I know they were built/exist, mine being just one survivng example.
None of the Mopar mags or books even acknowledge the N code 383 that was standard on 'Cuda was also the most powerful optional engine for BH23/BH27/BP23/BP27 - 727 auto and 4 speed cars, not even dated 1970 factory dealership Barracuda brochures mention N code as even an option, stating the 330hp L code was most powerful 383 for Barracuda...so very few were built, very few remain today.
My car was ordered with A/C, and the engine is painted a blue, not a trace of hemi orange on it anywhere, as in all HP 'Cuda engines should be. I recall an article or quote years ago by GG that a car ordered with A/C the engine is 440/350hp blue and not 440HP/375hp hemi-orange, even the air cleaner is blue, not black wrinkle paint.
This includes the BH and BP 4 speed cars - as a 3 speed was not available for N code for '70, right? Topic must also include the 1970 Challenger V8's (non-R/T's) maybe even SE's too. The confusion exists somewhat by assigning 383 2bbl and 4bbl's the same L code in VIN? Any thoughts guys?
Re: How many N code BH27 Barracudas built
[Re: ebodyseast]
#55586
04/03/08 12:03 AM
04/03/08 12:03 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Sounds like you own a really rare and cool car.
The "N" code and E63 on the fender tag only tell you the car came with a 383-4bbl; it does not tell you which version, 330 horse or 335 horse, the car actually recieved. Many sources incorrectly list the 68 and 69 H code and the 70 N code as the HP version of the 383.
You need the broadcast sheet to know which engine assembly was installed.
"L" is the code for the 2bbl 383. I don't think I've seen a source that lists the "L" code for a 383-4bbl 330 horse car.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 1_WILD_RT]
#55593
04/03/08 02:34 AM
04/03/08 02:34 AM
Posts: 500 NoVa
ebodyseast
NoVa
This totally conflicts with the 1970 Plymouth service manual and Pymouth 1970 Parts catalogs that states all N VIN code 383's are HiPerformance 335hp and all others 2bbl & 330hp)are L code!!!!!! Where did you get this info if you don't mind my asking, I've never seen anything like it before and it totally disagress with everything Mopar printed for their service departments to order the right replacement parts (cams, springs, etc.) Is it a 1970 dated Mopar document?? The 1970 dealer brochure never mentions the 335hp engine as optional for a 4 speed Barracuda or for any Barracuda. Either way, thanks for at least shedding light on this topic, you may be 100% correct...it would be no wonder the autos were painted blue, if they weren't HP motors to begin with, and the 4 spds orange if they always were. Someone mentioned once that the cam should be measured to see if it was to 1970 440HP/375hp specs and the corresponding color coded 440HP valve springs checked to their color. I don't know how to measure a cam, don't think you can. Thanks bro!!
[Re: ebodyseast]
#55594
04/03/08 02:45 AM
04/03/08 02:45 AM
Posts: 17,553 Las Vegas, NV
6bblgt
Las Vegas, NV
Sounds like you're trying to convince yourself or others that your car is "rarer" than it is. per GG's "white book" (should be fairly accurate ) built to US specs: 1970 Barracuda convertibles with 383 2bbl (automatic only) BH27L0B = 59 1970 Barracuda convertibles with 383 4bbl (automatic) BH27N0B = 36 1970 Barracuda convertibles with 383 4bbl (4-speed) BH27N0B = 17 1970 Barracuda convertibles with 383 4bbl (3-speed) BH27N0B = 6 also: 1970 Barracuda Gran Coupe convertibles with 383 2bbl (automatic only) BP27L0B = 54 1970 Barracuda Gran Coupe convertibles with 383 4bbl (automatic) BP27N0B = 66 1970 Barracuda Gran Coupe convertibles with 383 4bbl (4-speed) BP27N0B = 18 1970 Barracuda Gran Coupe convertibles with 383 4bbl (3-speed) BP27N0B = 2
[Re: ebodyseast]
#55595
04/03/08 02:50 AM
04/03/08 02:50 AM
Posts: 500 NoVa
ebodyseast
NoVa
This would also mean that an original numbers matching BS23 or BS27 'Cuda & original JS23 & JS27 R/T Challys - if you got the automatic and 383 you didn't get a Magnum or Super Commando engine, and I don't think there is an original owner out there that can say this is a fact. I've never seen a 330hp engine in a 1970 R/T or 'Cuda? All 'Cudas and all R/T's all had HiPo engines...4 speed or not. I think there is a hole in this answer...big time, and still room for lots of debate. I think this info you provided is false in these ways. IMO - what do you think, is there any truth in what I've stated, let's hear from someone that knows for sure. I knew this might be a hot topic of debate so don't take what I've said the wrong way. cool! that green chally vert you've got is bad [Edited by Moparts - Keep it clean] and you do know what you're talking about.
[Re: 6bblgt]
#55598
04/03/08 03:06 AM
04/03/08 03:06 AM
Posts: 27,596 So Cal
autoxcuda
So Cal
The b'cast sheet holds your answer: What is the 3 digit number under ENG on line 4? What is the 2 digit number under CARB following it on line 4?
1970 N code 383s were both 335hp orange HPs with HOLLEY carbs & 330hp blue with CARTER carbs.
Ebodyseast, your buildsheet has the answers to the part number of the motor and carb.
Please post the codes so we can learn more about this odd Mopar offering of two 70 383 4bbl motors. Educate us.
Re: How many N code BH27 Barracudas built *DELETED*
[Re: 6bblgt]
#55599
04/03/08 03:37 AM
04/03/08 03:37 AM
Posts: 500 NoVa
ebodyseast
NoVa
[Re: ebodyseast]
#55602
04/03/08 07:20 AM
04/03/08 07:20 AM
Posts: 2,601 Great White North
Furyman
Great White North
Looks to me like you are not reading Dan's posts.They are not confusing.An L Code car is a 2bbl ...not a 4 bbl.Galens production figures are taken from the 1970 SG 30's...an option and accesories report printed every year that breaks down all the options by percentage points.As stated ..the N code cars could have either the 330 or 335 horse 4 bbl engine....the SG30's do not differentiate between the two.I've seen 3 N code converts come up for sale in the last 3 years...only one had AC,one had the 335 horse eng with the 355 perf axle package and one had no fender tag.The actual production figure for these cars is probably closer to 50 as the 36 figure is for US cars only....does not include Canadian cars or Export Cars.
"Long Live Mopars"
[Re: gygeneral]
#55603
04/03/08 07:20 AM
04/03/08 07:20 AM
autoxcuda
So Cal
I have a JH Challenger Convertible with N code, I will pull the build sheet tonight and post those codes. I am curious, hopefully someone can tell us what they mean. I also have the original carb 4218 Holley with N95 on the car. I went through the same thing before starting the resto, and decided to keep it original instead of another R/T clone.
Did your Challenger orginally have the hood and stripe? A real insurance beater.
I remember a red 70 baracuda conv, N-code, 4spd, scooped hood, rallye gauge, console car about 7 or so years ago for sale at a Spring or Fall Fling. Another insurance beater. I wonder if it was any cheaper than just buying a similiar optioned 'Cuda vert.
It had dual cuda tips, but I'm sure they were added.
[Re: Furyman]
#55604
04/03/08 07:28 AM
04/03/08 07:28 AM
autoxcuda
So Cal
snip...the N code cars could have either the 330 or 335 horse 4 bbl engine....the SG30's do not differentiate between the two.I've seen 3 N code converts come up for sale in the last 3 years...only one had AC,one had the 335 horse eng with the 355 perf axle package and one had no fender tag...snip
I thought one question was did the buyer of a non 'Cuda or non R/T have the choice between serperate options of a 330hp or a 335hp ?? Or a choice in certain situations?
I understand it didn't show up on the SG report. But was there two seperate options and/or choices?
