Re: How much NOS will a cast crank take
[Re: scottb]
#555787
12/16/09 09:55 PM
12/16/09 09:55 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
I have always heard that a stock engine could take a 150 hp shot of nitrous. I ran my magnum motor at this level for 3 years before I build my 408.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: blk00rt]
#555788
12/16/09 10:26 PM
12/16/09 10:26 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
been sprayin a stock 360 bottom end since o4 .63 and .78 jets depending on track.. on a big shot plate. seems to be taking it...? dont know what that computes to ? it is polished rods and lightend rotating assy. with K.B. hypers.. fwiw.. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#555789
12/16/09 11:02 PM
12/16/09 11:02 PM
Posts: 4,679 On the parachute mount
n20mstr
i had a stock 360 bottom end with forged repl pistons, Stock crank stock rods etc, In my car it ran 13.00 on motor and 10.90 with nitrous, It had two plates stacked for a two stage, both jetted at 175each so yea that was 350hp on a stock crank stock rod motor. Keep it out of detonation youll be surprised at what lives..Id keep it to 175 though and you should be ok. A 360 cast crank is pretty beefy
....BAD A$$ STREET CAR.....
#555794
12/17/09 03:36 PM
12/17/09 03:36 PM
Posts: 1,868 Cali S.B
Sub95
super gas
super gas
Cali S.B
.068 around 200hp .078 around 275hp
most stock engines can take a 150 shot with no problems, as long as you take timing out and run good fuel, might have to put a colder plug in. just keep reading the plugs.
[Re: blk00rt]
#555795
12/17/09 08:37 PM
12/17/09 08:37 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
blk00rt did your magnum motor have hyperutectic pistons when you were spraying N.O.S. on it.If it did,were the rings gapped bigger for it.I have a 360/380hp crate motor and I was wanting to try spraying it without regapping the rings.Maybe 100 or 125.I only run 1/8 mile.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#555796
12/17/09 08:54 PM
12/17/09 08:54 PM
blk00rt
Michigan Troll
the 360 magnum was a completly stock lower end. It had hyper pistons and rings were never touched. I ran it for 2-3 years on the stock bottom block until I decided to change to the 408.
[Re: D-50]
#555799
12/17/09 09:18 PM
12/17/09 09:18 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
There's a number of guys on the Dakota R/T Forums spraying 150 on stock bottom ends, and have been for years...
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: D-50]
#555800
12/17/09 09:59 PM
12/17/09 09:59 PM
blk00rt
Michigan Troll
"Thanks for the info.Did you say you sprayed 150 on it?" yes, I do have a timing retard unit and I pull 1-2 degrees out but I dont really have to, I do it just to be safe.
