gold master cylinder cap a body #553983
12/14/09 07:36 PM
12/14/09 07:36 PM
chicago Burbs
demoned Offline OP
demoned  Offline OP
chicago Burbs
hello does any one have a gold cad master cylinder cap for sale or know were i can get one. I have ordered master cylinders from all the part stores around here none of them have it on it. I did pick up one with the same casting #s on it but none with the gold top. For 1971 a body drum brake car.
Re: gold master cylinder cap a body [Re: demoned] #553984
12/14/09 07:52 PM
12/14/09 07:52 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
There used to be someone on here that did it.It was the spray bomb method but it looked good enough for me.Most people say that my 70 should be black but I like cast master cylender and gold cap.
Re: gold master cylinder cap a body [Re: 70RR383] #553985
12/14/09 08:57 PM
12/14/09 08:57 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
When duey plated my brake booster I had him plate my MC cover and the 3 nuts that hold my heater assembly to the firewall.....
Dueys boosters in Portland OR...
Re: gold master cylinder cap a body [Re: minivan] #553986
12/15/09 12:29 AM
12/15/09 12:29 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
For plating, I use Eric Manuel on the board: username 3404, IIRC.
Re: gold master cylinder cap a body [Re: topside] #553987
12/15/09 01:27 PM
12/15/09 01:27 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Take it to a local plating shop and tell them you want Yellow Zinc Chromate plated on it. It's sort of iridescent, so it will have green hues and maybe some red colors depending on the light angle. There is usually a plating minimum charge ($50-$75), so take along a bunch of parts that needs the yellow zinc.
Floyd Lippencott IV
Re: gold master cylinder cap a body [Re: mr_340] #553988
12/15/09 03:14 PM
12/15/09 03:14 PM
P
Paul_Fancsali Offline
P
My master power master came with the top you describe
Re: gold master cylinder cap a body [Re: Paul_Fancsali] #553989
12/16/09 08:19 AM
12/16/09 08:19 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
The master cylinders for both my '75 drum brake Duster and the Stepson's Roadrunner came with the chromated covers. Both from Auto Zone.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
