66-67 plymouth , 275/60/15 on 8 in rim,what backspace? #552581
12/13/09 12:41 PM
12/13/09 12:41 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Any members running a 275/60/15 tire on an 8 inch rim,with stock rear wheel lip and springs,on a 66 or 67 PLYMOUTH B body ?
I need to know what offset will work as I want to order a set of steel wheels for my 1966 satellite.I know it is a very tight fit but I think you can run a 275/60.I am running 255's now and I need a taller wider tire.On a previous plymouth I fitted 275's on a 7 inch rim but the rim is not wide enough,thanks !
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: ogopogo] #552582
12/13/09 12:49 PM
12/13/09 12:49 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
4.5" backspace. It's a tight fit.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: moparpollack] #552583
12/13/09 01:39 PM
12/13/09 01:39 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Good luck with that one.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: StealthWedge67] #552584
12/13/09 01:44 PM
12/13/09 01:44 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
GEnsrud,ive seen a picture of your car in another thread,what size tires are you running? is your wheel lip still intact?
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: ogopogo] #552585
12/13/09 02:34 PM
12/13/09 02:34 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I have 245-15-60 on 15X8 wheels with a 5 1/4" BS.. I think a 5" bs would have been better.. Mine rubs a little on the inside fndr well on one side... 67 Dodge coronet....
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: ogopogo] #552586
12/13/09 02:36 PM
12/13/09 02:36 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
On my 66 Coronet a 5" backspace puts a 15x8 wheel right in the center of the useable area.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backsp [Re: mrrandyj] #552587
12/13/09 09:19 PM
12/13/09 09:19 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Here's pics of my 66 Coronet with 18x8" rims and 5.5" backspace. Tires are 255/45/18"
The rub mark in pic's 2 and 3 are from what was on the car when I bought it, not from the new tires/wheels.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backsp [Re: Lefty] #552588
12/13/09 09:56 PM
12/13/09 09:56 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Im pretty sure 4 1/2 is not enough backspace,and Im not confident that using dodge fitment with my plymouth is a good idea but I appreciate all the input.Hopefully someone will chime in who has these tires on a plymouth !!
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: ogopogo] #552589
12/13/09 10:12 PM
12/13/09 10:12 PM
T-Man Offline
T-Man  Offline
I believe the backspacing will be somewhere between 3 1/2" - 4".
That is an awful big tire to try to get into that wheel well. It may not fit!
67 plymouth satellite 72 plymouth roadrunner
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: ogopogo] #552590
12/13/09 10:43 PM
12/13/09 10:43 PM
Puyallup, WA
Puyallup, WA
I run a 245/60-15 on a 15x7 rim, 4-1/4" bs. The tire is perfectly squared up in the well with this setup. My lips are full intact, with chrome trim, no trimming at all. I have lots of room (about 3/4" on each side of the tire), and wish I would have gone to 255/60's, But 275's are going to be on the tight side. They will likely fit when the car is sitting, but driving around, I think they're gonna rub all the time. I could be wrong, I know guys run 275's in these cars, but with the llps cut, and a tall stance. If you're sitting at a stock stance, the lip isn't the tight spot. Its up in the well about 3" where the body contour steps in thats the pinch spot.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: StealthWedge67] #552591
12/14/09 10:41 AM
12/14/09 10:41 AM
T-Man Offline
T-Man  Offline
I'm thinking that if the BS on a 15 x 7 is 4 1/4" then on a 15 x 8 it needs to be 3 3/4". And that's what I've measured before.
67 satellite. Have G60-15 that need to get installed. I measured for 15 x 8 rims but thinking I might go to 15 x 7 just to be safe.
Let us know how it turns out.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: T-Man] #552592
12/14/09 12:28 PM
12/14/09 12:28 PM
Puyallup, WA
Puyallup, WA
You're going the wrong way with the backspace math. You're thinking correctly, though... If a 15x7 with 4-1/4" bs gets you centered, then a 15x8 will want 4-3/4". when you measure a rim, remember we're measuring to the tire bead, not the outside edge of the rim.
Just checked out your post re: your motor. I have a lot of experience with my 2-bbl / 270 horse 383. If you have any questions, don't hesitate to PM me.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: StealthWedge67] #552593
12/14/09 01:53 PM
12/14/09 01:53 PM
Jamey Online content
Jamey  Online Content
On my 67 belvedere I used an 8" wheel with 5" back space and had rubbing. I used a 1/4" spacer and have no rubbing now. So for my car 4 3/4" back space would be perfect. This is with a 275 60 15 M/T drag radial.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: Jamey] #552594
12/14/09 03:29 PM
12/14/09 03:29 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Jamey,
is your wheel lip intact,not cut or folded in? where are you rubbing,on the lip,or up top in the wheel tub? thanks for posting
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: StealthWedge67] #552595
12/14/09 04:22 PM
12/14/09 04:22 PM
T-Man Offline
T-Man  Offline
Yep went the wrong way on the back spacing. I agree it looks like 4 3/4" should be perfect.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: T-Man] #552596
12/14/09 06:59 PM
12/14/09 06:59 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I want to say the plymouth rear wheel houses must be different than the dodges... I do not think a 4 3/4 bs would have worked on my 67 coronet with 8" wheels....
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: minivan] #552597
12/14/09 10:31 PM
12/14/09 10:31 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
15x8, 4.5 backspace, 28x9x15 slick. Obviously I'm missing some of the wheel lip, but these otherwise fit fine.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: TC@HP2] #552598
12/14/09 10:33 PM
12/14/09 10:33 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
15x8 with 4.25 backspace, 275/60x15 tire. Also fit okay. If I did have a wheel lip, I wouldn't have hesitated to roll it for this fit.
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: TC@HP2] #552599
12/15/09 12:23 PM
12/15/09 12:23 PM
alabama
belvedere1967 Offline
alabama
I use 15x8 4.5 backspace and had to trim wheel lip, I think 4.75 would be better
Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace? [Re: belvedere1967] #552600
12/15/09 10:32 PM
12/15/09 10:32 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
well,looks like Id better order the wheels with 4 3/4 BS.Hey belvedere67,how about posting a full size picture of your car? it looks pretty sweet in your sig pic,im pretty tempted to buy a set of centerlines myself,they've always been my favorite aftermarket rim.
