Re: 66-67 plymouth , 275/60/15 on 8 in rim,what backspace?
[Re: ogopogo]
#2564837
10/16/18 02:29 PM
10/16/18 02:29 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I know this is an old thread but at one time, was there an offset spring hanger kit for these cars? (66 belvedere)
If not, could we make an Abody one work?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: TC@HP2]
#2565622
10/17/18 10:06 PM
10/17/18 10:06 PM
Posts: 1,031 ohio
67mprfan
ohio
Spring interference isn't the issue. Wheel well size is. In stock configuration the springs already sit inboard of the wheel well's inner wall. Plus I might be wrong but with offset hangers on left side of the car won't it hit the gas tank filler tube
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: hemirdrnnr]
#2566615
10/19/18 07:45 PM
10/19/18 07:45 PM
Posts: 1,031 ohio
67mprfan
ohio
"Plus I might be wrong but with offset hangers on left side of the car won't it hit the gas tank filler tube"
My 67 Belvedere is off set 5/8 to the frame front hanger and off set shackle in the rear and it clears nicely. Thanks wasn't sure if it would clear
