Old Crane Hemi cam grinds...
#551968
12/12/09 04:18 PM
12/12/09 04:18 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Anyone have any info on the following Crane Cams Mech roller Hemi camshafts. R 285/410-8 R 290/446-4 R 286/500-4 R 325 Im almost 100% sure the last set of numbers is lobe lift. There was a post on here several months ago that might have mentioned one of these cams. I would like to pick one that would best fit my application... 572 Hemi, heads flow 460cfm.700 lift, 13.8:1 compression, MP X-Ram.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Old Crane Hemi cam grinds...
[Re: Bob_Coomer]
#551970
12/12/09 04:32 PM
12/12/09 04:32 PM
Bob_Coomer
Rock Springs
Found this old DCX Cam chart..Looks like this is the specs for the 290 cam...I know some of the old Racer Brown cams were very close r shared the same specs alo.
6 Cyl. P4120243 D.C. 244-108 244 .436" 102 .010 .020 6 Cyl. P3690766 SS14-112 268 .450" 108 .016 .020 6 Cyl. P3690768 ST21-110 286 .520" 108 .016 .020 A Eng. P3412044 68 340 Man.-114 276/284 .444/.453" 112 Zero A Eng. P3690213 Street Hemi GT-112 284 .471/.474" 109 Zero A Eng. P3690769 SSH-44-108 292 .510" 110 Zero A Eng. P4007619 SSH-25/44 286/292 .485/.510" 108 Zero A Eng. P4007275 C. D. Stock "Cheater" 336/348 .462/.473 108 Zero A Eng. P4120231 D.C. 284-108 284 .484" 108 Zero A Eng. P4120231 D.C. 292-108 292 .509" 108 Zero A Eng. P3412016 ST21-108 286 .520" 110 .018 .022 A Eng. P2836146 STX21-105 306 .560" 105 .028 .032 A Eng. P4120653 D.C. 284-112 284 .542" 110 .028 .032 A Eng. P4120655 D.C. 296-110 296 .572" 108 .028 .032 A Eng. P4120657 D.C. 312-106 312 .606" 104 .028 .032 A Eng. P4120148 D.C. 320-102 320 .630" 100 .024 .028 A Eng. P3690795 R280-427-1 10 Crane *280 .640" 108 A Eng. P3690589 Magna. Velocity-110 324 .633" 110 .024 .028 A Eng. P4007278 R-278-284-.413-.427-06 *278/284 .620/.640" 106 .035 .035 Cam Dyn. A Eng. P4007509 R-284,427-05 Cam Dyn. *284 *284 108 .035 .035 A Eng. P3690796 R-296-4778-1 10 Crane *296 .717" 109 .024 .028 B Eng. P3690214 Street Hemi Gr.-108 284 .471/.474" 106 Zero B Eng. P3412073 SSH-25-108.5 286 .485" 108 Zero B Eng. P3690812 SSH-44-108 292 .510" 106 Zero B Eng. P4007277 C.D. Stock "Cheater" 352/380 .467/.483 108 Zero B Eng. P4120235 D.C. 284-108 284 .484" 108 Zero B Eng. P4120237 D.C. 292-108 292 .509" 108 Zero B Eng. P3690816 Stage 11-115 300/308 .518" 110 .028 .032 B Eng. P4120659 D.C. 284-112 284 .528" 110 .028 .032 B Eng. P4120661 D.C. 296-110 296 .557" 108 .028 .032 B Eng. P4120663 D.C. 312-106 312 .590" 104 .028 .032 B Eng. P3690159 STX-22 310 .590" 108 .028 .032 B Eng. P3690588 Mini Express-107 316 .654" 107 .024 .028 B Eng. P4120042 R280-.4468-08 Crane *280 .670" 108 .035 .035 B Eng. P4007279 R286-500-108 Cam Dyn. *286 .750" 107 .035 .035 Hemi P3690814 SSH-44-108 292 .510" 106 Zero Hemi P4007945 C.D. Stock "Cheater" 342/348 .490/.480" 103 Zero Hemi P3412090 STX22-105 310 .590" 104 .028 .032 Hemi P3571029 725-105 340 .643/.623" 103 .028 .032 Hemi P3690587 Mini Express-104 324 .684/.663" 103 .024 .028 Hemi P3690591 R-290-446-104- Crane *290 .700/.678" 103 .028 .032 Hemi P4007253 R292-500-106 Cam Dyn. 0292 .785/.760" 103 .032 .032 Hemi P3690839 R-296-4778-108 Crane *296 .750/.726" 108 .032 .032
Post deleted by Defbob
[Re: Bob_Coomer]
#551971
12/12/09 04:37 PM
12/12/09 04:37 PM
[Re: Bob_Coomer]
#551972
12/12/09 04:46 PM
12/12/09 04:46 PM
Bob_Coomer
Rock Springs
Found the specs for the following cam also.
R286/500-4 286/292 dur at .050 Lift .785/.760
Opens Closes ADV Duration Intake 51.0 BTDC 95.0 ABDC 326.0 ° Exhaust 102.0 BBDC 50.0 ATDC 332.0 °
Looks like this one has a pretty wide LSA...like 113.5-114....
[Re: Bob_Coomer]
#551974
12/12/09 04:51 PM
12/12/09 04:51 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
isn't that normal for a Hemi grind? to reduce the intake charge loss out the exhaust?
[Re: Bob_Coomer]
#551977
12/12/09 05:54 PM
12/12/09 05:54 PM
[Re: TS3303]
#551979
12/13/09 09:51 AM
12/13/09 09:51 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
When we were running hemi's back in the day, we shrunk the exhaust valve to 1.85", and were going to go with smaller exhaust lobes.
[Re: Bob_Coomer]
#551980
12/13/09 04:03 PM
12/13/09 04:03 PM
Posts: 3,505 DFW
mr_340
DFW
I replied to your PM.
Floyd Lippencott IV
[Re: RAT PATROL]
#551983
12/15/09 01:29 PM
12/15/09 01:29 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
The Crane R290-446-04 is the oldest cam, an early SS Cam, 290 @.050 int and exh, .446 lobes int and exh, LSA 104, 82 overlap, gross Int lift .700, Exh .678. This was generally replaced by the R292-500-06, .500 lobes, LSA 106, 80 overlap, gross lift .785/.760. The SS/DA cam was the R286-500-04,.500 lobes, LSA 104, 78 overlap, gross lift .785/.760. The R296-4778-08 was known as a 4 speed SS/A cam, .478 lobes, LSA 108, 80 overlap, gross lift .750/726.
Be a Rebel- Break the Laws of Physics!
[Re: mbogina]
#551984
12/15/09 01:35 PM
12/15/09 01:35 PM
#551985
12/15/09 07:40 PM
12/15/09 07:40 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Dont know if this will work.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#551987
12/15/09 11:29 PM
12/15/09 11:29 PM
Posts: 501 ONTARIO,CANADA
604 Hemi GTX
ONTARIO,CANADA
Were did you find the info for hemi grind cams...i've been looking with no luck.. here's my cam info R296/435-10X 66-2096 any help would be appreciated...not trying to hi-jack this thread.
[Re: mgpanos]
#551988
12/16/09 02:40 PM
12/16/09 02:40 PM
Posts: 4,233 State of retirement
52savoy
State of retirement
The R286/500-4 was commonly used in the Super Stock Hemis in the late 70's and maybe early 80's. The R290/446-4 was the first popular Crane grind for the Pro Stock-style Hemis, but was a killer on valve springs. It was replaced by the R296/4778-8 which wasn't quite so hard on springs even with more lift. I have never heard of the R285/410-8 but suspect it was for the heavier Super Stock cars.
Mark
Your right...the R290 was the first really big cam used in early HEMI pro/stockers and it found it's way over to super/stock. I've been using that cam for about 30 years and still love it.. My newest HEMI stroker(478) is using it and the motor will be going in my "SILVER BULLIT" clone.
The cam specs very from make to make. So the cam card showing it over 700lift is wrong for a HEMI. Get an early('71-'74) Crane Cams catalog! Fred
[Re: 52savoy]
#551989
12/16/09 02:49 PM
12/16/09 02:49 PM
#551990
12/16/09 02:54 PM
12/16/09 02:54 PM
52savoy
State of retirement
one Fred to another.... The chart "deaks" posted might be for a Ford or Chevy..(different makes). I have a '73 catalog and it shows different cam specs depending on the make of engine.
[Re: Bob_Coomer]
#551992
12/16/09 04:15 PM
12/16/09 04:15 PM
deaks
robin hood country
You could be right, although i was looking for info on the R280 and 286 at the time and the R280 specs tallied with my R280 measurements. Mick
[Re: deaks]
#551993
12/16/09 04:34 PM
12/16/09 04:34 PM
Posts: 7,497 Austin, TX
HemiDave
Austin, TX
I feel your pain! I 'inherited' a stack of Hemi cams with little info... Trying to figure the specs on this one: Dave
