Page 1 of 3 1 2 3
Small Block Edelbrock Heads #549920
12/09/09 08:52 PM
12/09/09 08:52 PM
Bakersfield, CA
MarkKirby Offline OP
Bakersfield, CA
This may have been covered here previously but in your opinion who puts out the best small block Edelbrock heads, either CNC or custom ported? I have talked to Hughes, Indy, and a couple local head experts with mostly similar pricing and theories on performance.
This is for a race only stroker.
Mark & Nancy Kirby 1971 Plymouth Duster The Grape Ape 10.20 @129mph 1.32 60'
Re: Small Block Edelbrock Heads [Re: MarkKirby] #549921
12/09/09 09:27 PM
12/09/09 09:27 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I'll get the ball rolling. How big will the engine be?
How much does the car weigh and what is your goal for it?
Re: Small Block Edelbrock Heads [Re: S/ST 3040] #549922
12/09/09 10:12 PM
12/09/09 10:12 PM
Bakersfield, CA
Bakersfield, CA
The specs are below....although my question is really about who is the best supplier.
416" 340 +30
4" Steel crank, H-beam
Dynoed at 575hp@6500, 550lbs torque @4700
Ported J Heads flowing approximately 270 @.600"
Gary Stinnet HP950 on Super Victor
Cam: 627"/637" 276/281 @.050"
3300lb A-Body
Low gear 904
5.13 Dana
4-link
16 x 33 GYs
Stock front suspension
10.40 @125.00
1.37 60'
The car works well the way it is currently setup. However, I am looking to push it over 600hp to gain mph when running Super Street and a couple tenths padding on a 10.60 index.
Re: Small Block Edelbrock Heads [Re: MarkKirby] #549923
12/09/09 11:17 PM
12/09/09 11:17 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
given your location, I'd talk to board member OU812, Brian at IMM.
other good small block porters: Jeff at Modern Cyl, and Ryan J at Shady Dell Speed Shop
2017 Grand Cherokee Overland
Re: Small Block Edelbrock Heads [Re: patrick] #549924
12/09/09 11:21 PM
12/09/09 11:21 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
If you MUST buy Edelbrocks get the IndyBrocks. I have tried both and I dont care what the flowbenches say.....the IndyBrocks were faster on the SAME engine...
Re: Small Block Edelbrock Heads [Re: DaKuda] #549925
12/10/09 12:01 AM
12/10/09 12:01 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Lighten the car. There's no way that duster should weight 3300# unless your 400#.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block Edelbrock Heads [Re: patrick] #549926
12/10/09 12:02 AM
12/10/09 12:02 AM
Bakersfield, CA
Bakersfield, CA
Brian at IMM is an absolute genius when it comes to small blocks. I have talked to Indy about the IndyBrocks but at close to $4grand I don't see the value.
I don't need to go the full blown Indy route because I don't need to pickup 100hp....perhaps just half of that. However, although the Eddies will give me less HP gain they are certainly not HALF the cost of the Indy kit. And as far as Shady Dell is concerned...I just can't get him on the phone in spite of numerous tries.
Re: Small Block Edelbrock Heads [Re: MarkKirby] #549927
12/10/09 12:15 AM
12/10/09 12:15 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
My complete IndyBrock kit was $2200 with rockers pushrods and gaskets....
Re: Small Block Edelbrock Heads [Re: MarkKirby] #549928
12/10/09 12:17 AM
12/10/09 12:17 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Mark..
the Indybrocks are an edelbrock head that has the intake pushrod offsetted aka TA/W2 head. He is not talking about the Indy 360-1 heads, just an indy modified eddy head.
Tony
70 AARCuda Vitamin C
Re: Small Block Edelbrock Heads [Re: 70AARcuda] #549929
12/10/09 12:21 AM
12/10/09 12:21 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
100% here.
Re: Small Block Edelbrock Heads [Re: MarkKirby] #549930
12/10/09 12:58 AM
12/10/09 12:58 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
416" 340 +30
Dynoed at [Email]575hp@6500[/Email], 550lbs torque @4700
3300lb A-Body
Low gear 904
5.13 Dana
4-link
16 x 33 GYs
10.40 @125.00
1.37 60'
I have seen your car run, you have done alot of tricks to it no matter how much it weighs. Can you tell me the front to rear bias. And you can't go wrong with either Brian or Ryan, I have seen first hand from both guys 60HP gains in just their head porting, no other changes. of course you will save some freight and travel time getting them to mad man Brian but both guys even help each other out on both coasts. Good guys in my book. Good luck.
Re: Small Block Edelbrock Heads [Re: 68Fastback] #549931
12/10/09 11:25 AM
12/10/09 11:25 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I have been using Vic(S/ST3040)with great results.I bet by his questions he was wondering if an Edelbrock head would be able to support what you were intending to use it for.
Edelbrock heads can only move X amount of air,no matter who does the port work.The Indybrocks with their relocated push rod locations probably help since most porters crowd the push rod pinch anyway.
Re: Small Block Edelbrock Heads [Re: Dunnuck Racing] #549932
12/10/09 12:08 PM
12/10/09 12:08 PM
S/ST 3040 Offline
S/ST 3040  Offline
Using the trusty Moroso Power/Speed calculator, I have his 416 @ 495 HP and your 421 @ 520 HP.
I think the INDY version of the RPM is worth some power, espesially on
a 4"+ stroker. Keith's are as big as I could get with tubed pushrods and
I think it would be faster if I could have opened them up another .100".
I'd also consider a different cam on the 416.
Re: Small Block Edelbrock Heads [Re: Dunnuck Racing] #549933
12/10/09 12:13 PM
12/10/09 12:13 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
based on your current performance,( heads you have already) i would expect a set of well done eddie heads to be 2.5- to 3 tenths better than what you have currently. Not to mention a pretty decent weight savings, that you can factor in as well.
knowing what i know now, and people i have talked to over the past few years, i would recommend the hughes head and the full cnc porting they offer. you are just going to have more uniformity cylinder to cylinder over hand porting, and hughes's cnc program is on the agressive side as well, they produce a nice head, a local friend just ordered a set for his 408 ...i dont see any reason whatsoever you shouldnt pick up at LEAST 40 horsepower over what you currently have, if not a little more.
there are other heads that obviously will offer a bigger gain( indy/w5, etc) but if your goals are as you stated above, the cnc eddie heads from Hughes are, IMO, easily capable of the upgrade in performance to suit your requirements.
they do a lot of work with iron heads as well, give them a call and ask their opinion of a max set of eddies compared to your j heads.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Small Block Edelbrock Heads [Re: S/ST 3040] #549934
12/10/09 08:46 PM
12/10/09 08:46 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
Vic, You port heads also?
Re: Small Block Edelbrock Heads [Re: Lil Wedge] #549935
12/10/09 09:37 PM
12/10/09 09:37 PM
S/ST 3040 Offline
S/ST 3040  Offline
Yes but, I try to stick with SB heads as much as I can though.
Re: Small Block Edelbrock Heads [Re: S/ST 3040] #549936
12/10/09 09:42 PM
12/10/09 09:42 PM
S/ST 3040 Offline
S/ST 3040  Offline
...and the heart breaker.
Re: Small Block Edelbrock Heads [Re: S/ST 3040] #549937
12/10/09 10:49 PM
12/10/09 10:49 PM
utica ny
meus31 Offline
meus31  Offline
utica ny
all right i have a question . what is the best anyone has ever seen or had a edelbrock run at the track. pump gas or race fuel just tell us what it was so we can compare apples to applesand race weight if you know it.
Re: Small Block Edelbrock Heads [Re: meus31] #549938
12/10/09 10:54 PM
12/10/09 10:54 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
My Cuda ran 6.70 in the 1/8th on BOX STOCK eddys. 3000lbs 340 non stroked. 1.40 60ft time.
Re: Small Block Edelbrock Heads [Re: DaKuda] #549939
12/10/09 11:33 PM
12/10/09 11:33 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Pretty happy with the Eddies with just a backcut intake, a sharp valvejob and opening up the Pushrod Pinch, of course mines just a little 341 mini stroker so I'm not taxing them all that hard!
http://www.youtube.com/watch?v=BWfK6cs8isE
WIZE
In Car:
Page 1 of 3 1 2 3
