Notching Chrome Moly #549417
12/09/09 12:53 AM
12/09/09 12:53 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Is a special hole saw needed for notching chrome moly tubing??
I need to notch a couple tubes of chrome moly for my buddy's race car and all I have is the 1 5/8 bi-metal hole saw I used when I did my MS cage. I want to make sure I don't mess up the saw. I've never even touched a stick of CM, so please excuse my ignorance.
Thanks guys!
Re: Notching Chrome Moly [Re: mopowers] #549418
12/09/09 12:55 AM
12/09/09 12:55 AM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
The key is to use a slow speed when cuttin moly with a hole saw. The tips burn out quick when using a high speed drill. I have use wood and metal saws with great results. I now use holehawgs in my vertical mill, but I do a lot of notching---Greg
www.bcrproducts.com
Re: Notching Chrome Moly [Re: bcrproducts] #549419
12/09/09 11:22 AM
12/09/09 11:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
www.bcrproducts.com
go slow... you can buy the multi purpose
hole saws but buy good one.... dont press hard or it'll
chip the teeth off
Re: Notching Chrome Moly [Re: mopowers] #549420
12/09/09 10:45 PM
12/09/09 10:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I forget what brand but they're white in color from Home Depot or Lowes. I did my entire Chrome Moly cage with one hole saw. It still cuts fine.
Doug
