Re: Edelbrock CH28 dual quad experiences
[Re: AndyF]
#549190
12/14/09 11:57 PM
12/14/09 11:57 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Andy, Waiting to see your dyno results! looks great. Do you think the AVS (s) will sync up on them with just the spring tension being set close? or is it even an issue? What fuel pump will/would you use if this goes in a car? more
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#549191
12/15/09 04:08 PM
12/15/09 04:08 PM
Posts: 5,935 Athens, Greece
Pyper70
Athens, Greece
For my Dual quad setup I have the Edelbrock 110GPH mechanical on standby when I do the swap...I didnt wanna go with an electric fuel pump....I dont like too much electric stuff (water pump, fans, etc)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#549192
12/15/09 05:19 PM
12/15/09 05:19 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Have been running mine for two years now and am very satisfied. Mild street build.
BigBlock 74 Swinger
[Re: NV69B7RR]
#549194
12/19/09 10:03 PM
12/19/09 10:03 PM
Posts: 31,319 Oregon
AndyF
Any advice on what bracket to use for the throttle cable?
I designed a throttle linkage kit that works with a stock Mopar throttle cable. I'll have these kits avaiable for sale by the end of the year.
[Re: AndyF]
#549195
12/20/09 12:12 PM
12/20/09 12:12 PM
Posts: 4,880 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Andy I absolutely love that air cleaner assembly! Is the base made of stamped steel? I plan to run that unit with base mods to fit my Offenhauser for the 360.
Keep old mopars alive.
[Re: NV69B7RR]
#549196
12/20/09 12:51 PM
12/20/09 12:51 PM
Posts: 10,134 MI, usa
dvw
MI, usa
My friend runs that intake on his 65 Plymouth. 650 Eddys,.557 Mopar solid, bowl jobbed 906, small headers,4.56 It runs 11.50@114. Very consistant. Basicly a street car no cage,subframe connectors,electric water pump. We have never run any other intake though we did try 750 Eddys which were no help. Never changed the stock jetting. We have open spacers under the carbs and the stock Hemi style scoop is sealed to the hood. We used the stock throttle cable. Doug
[Re: dvw]
#549197
12/20/09 07:27 PM
12/20/09 07:27 PM
Posts: 6,005 Reno, Nevada
NV69B7RR
Reno, Nevada
Andy, How much is the kit? PM me when they're availabe. Thanks, Brent
[Re: NV69B7RR]
#549198
12/20/09 11:11 PM
12/20/09 11:11 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
I got my sleeper air cleaner done on mine...don't laugh, it hides everything including the NOS. Silly but fun.
BigBlock 74 Swinger
[Re: NV69B7RR]
#549200
12/22/09 01:28 PM
12/22/09 01:28 PM
AndyF
Andy,
Thanks, Brent
I'll sell you the kit that is in the picture. It is my prototype kit but it works just fine. Shoot me a PM if you're interested.
My 505 motor made a little over 600 hp with the CH-28 setup. I was running twin 500 cfm Edelbrock carbs and a Comp 292HR hyd roller cam.
[Re: AndyF]
#549201
12/22/09 02:19 PM
12/22/09 02:19 PM
what did it make hp wise without that thing under the carbs? what rpms?
#549202
12/22/09 03:05 PM
12/22/09 03:05 PM
Pyper70
Athens, Greece
What are the threads that go inside the Carter fuel inlet? I need to order up a set of the Zinc Plated -6 AN but unclear as to that size
[Re: Fury Fan]
#549206
12/22/09 04:36 PM
12/22/09 04:36 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
Hey AndyF, that's the aircleaner I suggested to you - looks so much better than that chrome one! I'd suggest you give me a copy of your book in exchange for such a good tip, but I already bought a copy.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
