Re: New best, finally, on 275s
[Re: ProSport]
#545497
12/05/09 07:46 PM
12/05/09 07:46 PM
Posts: 489 mid Ga.
W5Dart378
mid Ga.
Thanks guys,Yes I have a 7531 and played with the slew rate stuff with the 904 tranny, had it dailed in pretty good. Now with the 2 speed it is all different and havent adjusted it. I'm using the Edelbrock progressive. It has been a pretty steep learning curve this year with the progressive and radials and stepping up the nitrous tune with the limited number of passes. Thanks to Eric Kenward (ORSCA Modified street champ)for a little help with the progressive. Hopefully it warms up around here so I can do some testing.Need to get down in the 5.20s.
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s
69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
[Re: W5Dart378]
#545500
12/07/09 01:19 PM
12/07/09 01:19 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The car looked the best I have seen it look at Steele. It was obvious that it is starting to come around. Good luck with it. Modified Street is a tough class, be nice to see a Mopar do well there.
Monte
