Re: Degree wheel pointer
[Re: AndyF]
#545312
12/04/09 10:33 PM
12/04/09 10:33 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Yeah.......since you are doing a SB now, you can make one of those for the rest of us. (With indicator at same angle as 59º lifter of course) BTW, that's a $40.00 Moroso 18" degree wheel.
[Re: Old School]
#545315
12/04/09 11:40 PM
12/04/09 11:40 PM
Posts: 31,344 Oregon
AndyF
Another view showing the pointer as well as the tool that holds the dial indicator over the lifter bores.
i like the dial indicator stand.does the indicator have a long stem,or is it on the pushrod?are they for sale?
I do sell a cost reduced version of that dial indicator stand. Part number AR246. You can get them from Hughes Engines. Big block only. Might fit Hemi also, never tried it myself.
[Re: hemi-itis]
#545319
12/05/09 10:35 AM
12/05/09 10:35 AM
Posts: 91 under a rock
flathood
under a rock
... a bent piece of coat hanger...
Uhhh... that's all I ever use. Oh, and a bolt & washer to attach it to the block.
Same here.... a piece of 1/16" tig rod(I dont have any coat hangers in the shop)
Me three ,and they are totally adjustable and come in different colors
Now thats a piston stop!
You likey?Than you would love the roller lifter with the bolt welded in the pushrod seat location for a nice spot for the dial indacator actuator
I use the same setup.Made by poorfolk LTD
[Re: flathood]
#545320
12/05/09 10:42 AM
12/05/09 10:42 AM
Posts: 7,506 Az
Crizila
Az
My dial indicator plunger rides on 2 gutted hyd lifters with a section of 1/2" pipe jammed between the lifters. Works great.
Fastest 300
[Re: Scamp451]
#545321
12/05/09 04:26 PM
12/05/09 04:26 PM
Posts: 3,559 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Scamp,
This is the one I was talking about....best one out there...you'll love it.
RIP Monte Smith
[Re: AndyF]
#545323
12/06/09 02:48 AM
12/06/09 02:48 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Andy, I looked and searched The Hughes Engines web site and could not find the indicator holder listed? How much does it sell for?
[Re: CompWedgeEngines]
#545324
12/06/09 03:46 PM
12/06/09 03:46 PM
Posts: 6,745 Abilene, Texas
fastmark
Abilene, Texas
Scamp,
this is the one I have. I bought it from a place called PMS I believe through my local engine builder/machine shop.
[Re: 451Mopar]
#545325
12/07/09 04:53 PM
12/07/09 04:53 PM
AndyF
I'm pretty sure Hughes has at part on hand. Call Kevin at Hughes and ask them. If they don't have them on hand they can order them, I have them in stock. They might have just forgotten to put the picture on the website. You'll have to check with them on pricing.
