Re: Powdercoating a rear axle, who's done this? [Re: gtx6970] #544812
09/21/11 11:56 AM
09/21/11 11:56 AM
dogdays Offline
dogdays  Offline
Cost me $150 to have two security doors blasted and powder coated. They had a lot of decorative metalwork so must have been a bear to blast. After it was done the company owner told me we could have had a zinc-rich primer applied first. Maybe that's something to think about.
R.
Yes, he told us AFTER the coated doors had been delivered!
Re: Powdercoating a rear axle, who's done this? [Re: 1_WILD_RT] #544813
09/21/11 06:00 PM
09/21/11 06:00 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
An example of Dr. Diff's work. He did this for me...
Re: Powdercoating a rear axle, who's done this? [Re: MoparMarq] #544814
09/21/11 07:03 PM
09/21/11 07:03 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Ok. You knew it was coming... Where does the disc brake set up come from?
Thanks.
Re: Powdercoating a rear axle, who's done this? [Re: lahatte] #544815
09/21/11 07:30 PM
09/21/11 07:30 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Thanks.
probably the good Doctor.
looks like his handiwork!
**Photobucket sucks**
Re: Powdercoating a rear axle, who's done this? [Re: MoparMarq] #544816
09/21/11 07:38 PM
09/21/11 07:38 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
I'm also curious, what are you matching with it up front?
Re: Powdercoating a rear axle, who's done this? [Re: lahatte] #544817
09/21/11 10:49 PM
09/21/11 10:49 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
Thanks.
it looks like a GM metric off a fullsize cadillac with a tag axle---bob
Re: Powdercoating a rear axle, who's done this? [Re: savoy64] #544818
09/21/11 11:55 PM
09/21/11 11:55 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
That is the all the good Dr. Diff's handiwork. '71-2 rear housing with his 10.7" disc brake swap. He can give you better details, but IIRC, the calipers are Mustang Cobra rear calipers with the incorporated cam-actuated parking brake. Discs are off a late '80s Toyota Cressida/Supra (same exact discs as on my '86.6 Supra) with the register bored slightly to fit the 8-3/4 axle. Discs have the inner drum for the parking brake on the Supra, but I've found it's pretty ineffective on my Supra, even though adjusted properly and shoes have plenty of meat.
Custom parking brake cables supplied by him with the kit, but built by another vendor. Hook right up to the existing e-brake cable at the frame rail attach points.
Had the fronts before I purchased his rear setup.
But matches to front fairly closely, according to
Cass. The fronts are 1st gen Viper calipers on the brackets built by AR Engineering, bolted to A-body drum brake spindles. M/C is a MP unit, 1-1/32" diameter bore, IIRC, (maybe 1-1/16"). Haven't driven the car yet, as kids and jobby-job occupy most of my time, but pedal is firm and travels an appropriate amount of distance to reach firmness, for my taste. Whether it stops well without two feet on the pedal, I have yet to determine. Prop valve is an old Direct Connection adjustable unit, for nostalgia's sake.
Sorry for the hijack...
Re: Powdercoating a rear axle, who's done this? [Re: MoparMarq] #544819
09/22/11 12:28 AM
09/22/11 12:28 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Thanks for the informative reply.
