Still Trying to find throttle cable #544707
12/04/09 10:56 AM
12/04/09 10:56 AM
Warrenton, VA
65Coronet7165 Offline OP
Warrenton, VA
Car is a 67 Chrysler 300 with 440 4bbl.
I need a throttle cable....I tried Stephen's Performance....I've been waiting 2 weeks and now they tell me they had to have it custom made and will take at least another week.
I need a cable NOWWWWWWWWWWWWWW. If someone can at least tell me how long this cable is supposed to be I can order a cable from Mancini Racing. Measuring my cable won't help...my cable is WRONG
Re: Still Trying to find throttle cable [Re: 65Coronet7165] #544708
12/04/09 11:00 AM
12/04/09 11:00 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Can't you get a idea of the length needed from your old/wrong cable?
Re: Still Trying to find throttle cable [Re: Challenger 1] #544709
12/04/09 11:14 AM
12/04/09 11:14 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try Imperial Services.They probally have it in stock.They can make any that you need.Ask for Steve.Rocky
Chrysler Firepower
Re: Still Trying to find throttle cable [Re: 65Coronet7165] #544710
12/04/09 11:54 AM
12/04/09 11:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Won't a /6 cable work? Could you modify yours? or a stock BB cable? I'll check w/ a buddy he has had a few of those C'bodys. I bet he has 5 of them in his stash
Coming soon!!!!
Re: Still Trying to find throttle cable [Re: Mr.Yuck] #544711
12/04/09 12:16 PM
12/04/09 12:16 PM
Warrenton, VA
Warrenton, VA
Thanks! I can't use my cable...it is too long. My car has dual quads and the front carb is the primary...A "rigged" job by the original selling dealer. They never set it up properly. I've had the car almost 5 years now and I'm tired of dealing with it so I'm going back to single quad operation.
Re: Still Trying to find throttle cable [Re: 65Coronet7165] #544712
12/04/09 12:35 PM
12/04/09 12:35 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Try here: http://crossramconnection.com/
I'm running a '64 race Hemi cable on my B stroker. Ask for the shortest cable they have.
Re: Still Trying to find throttle cable [Re: 65Coronet7165] #544713
12/04/09 01:38 PM
12/04/09 01:38 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I just talked to my friend. He says any C-body cable will work. He bets your local junk yard has at least 20 of them.
Coming soon!!!!
Re: Still Trying to find throttle cable [Re: 65Coronet7165] #544714
12/04/09 02:00 PM
12/04/09 02:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Make you primary carb your rear the way it's supposed to be.You can use a regular BB cable and save yourself a lot of problems.
Re: Still Trying to find throttle cable [Re: 62maxwgn] #544715
12/04/09 02:27 PM
12/04/09 02:27 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
he is switching to a single 4 bbl?
Re: Still Trying to find throttle cable [Re: 62maxwgn] #544716
12/04/09 02:28 PM
12/04/09 02:28 PM
Detroit, MI.
Mancini Racing Offline
Detroit, MI.
Call our store and ask for Tony with an approximate measurement and we can check the length on the inventory we have listed below.
http://chucker54.stores.yahoo.net/hemthrotcab.html
Thanks,
Mancini Racing
586-790-4100
800-843-2821
www.manciniracing.com
Re: Still Trying to find throttle cable [Re: Mancini Racing] #544717
12/04/09 04:48 PM
12/04/09 04:48 PM
Warrenton, VA
Warrenton, VA
OK 62MAXWagn....your dual carb set up looks like the way mine should be! Same single plane manifold with 2 Carter AFB's. Yuor tranny kickdown linkage looks totally different from mine though...
Yeah, I'm switching from dual quads to a single quad....it's a PAIN the way its set up now for a variety of reasons. It's kind of a shame, but I'm hoping to accomplish at least these things by doing so:
1) Get the engine to idle right and be responsive off the line. As it is now, response is kinda lazy unless you give the throttle a good wack.
2) I've been having a hell of a time keeping both carbs in synch...causing part throttle surging and occasionally throttle on rear carb does not close down all the way giving a WAY high idle.
3) Less fuel fumes...I know gas now-a-days is super volatile with the added ethanol and my car doesn't have a vapor recovery system...but with ONE carb sitting on the manifold with a big enough air filter to absorb the fumes...its gotta be better than TWO carbs sitting there with tiny air filters.
4) The engine should LAST longer getting a better distributed fuel mixture.
5) Dare I mention it...I'm getting say 10, 11 or at best a hair over 12 mpg if I can get 13, 14 or 15 instead it would be a big improvement. Not only money wise, but I do quite a bit of driving and having to stop for fuel less often is a big convenience factor.
Re: Still Trying to find throttle cable [Re: 65Coronet7165] #544718
12/05/09 03:35 PM
12/05/09 03:35 PM
Randleman NC
GreenDartGo Offline
GreenDartGo  Offline
Randleman NC
LOKAR.com has cables also _ I will have eto get mine from them Knoxville TN
