Re: 66 barracuda headliner ?
[Re: Jim_Lusk]
#543891
12/03/09 03:56 PM
12/03/09 03:56 PM
RapidRobert
I just did my 65 dart which should be similar if not identical and my windshield/gasket were in but not sealed & it looked way more difficult to do the front of the headliner w the glass/gasket in place so I took it back out & did the headliner the put the wshield/gasket back in & sealed it but if it was in & sealed w the goop I'd get a helper to open the gasket edge as you put the headliner on/over the serrated teeth. A helper or 2 is a must.
