Re: Strongest paint remover is.....
[Re: Topcat]
#542584
12/01/09 11:33 PM
12/01/09 11:33 PM
Posts: 7,863 Colorado
Leadfoot
Colorado
Carlin described a fart that could strip the varnish off a footlocker. ![](/ubbthreads/images/graemlins/fart.gif) Serious, I think what you may be describing as the original paint is the original primer. This stuff just doesn't seem to want to come off with paint stripper.
[Re: Topcat]
#542585
12/01/09 11:35 PM
12/01/09 11:35 PM
Posts: 4,848 Memphis
HemiRick
Memphis
there's no real need to remove the factory primer it's excellent stuff.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#542588
12/01/09 11:52 PM
12/01/09 11:52 PM
Posts: 1,247 Fremont, CA.
Topcat
Fremont, CA.
Actually, it's the original Hemi orange paint that's not lifting.
The Jasco stuff is practically worthless. Aircraft stripper will do it. If your local hardware store doesn't have it, an automotive paint supplier will.
Thanks, I'll go get that and try it.
[Re: Leadfoot]
#542591
12/02/09 12:31 AM
12/02/09 12:31 AM
Topcat
Fremont, CA.
I thought the same thing. What I thought was Y3 paint was really primer of the same color and it just didn't come off.
A colored primer? I didn't see anything under it a different color.
[Re: HemiRick]
#542594
12/02/09 11:09 AM
12/02/09 11:09 AM
Posts: 3,958 SW Fla.
CYACOP
SW Fla.
I agree, if it's that hard to get off, leave it on. Gets back to the same argument when I see someone trying to remove the undercoating.
[Re: CYACOP]
#542595
12/02/09 12:28 PM
12/02/09 12:28 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Personally, once you have used paint remover over it I would be very hesitant to paint over it as it may come up or wrinkle in the future...
[Re: minivan]
#542596
12/02/09 05:07 PM
12/02/09 05:07 PM
Topcat
Fremont, CA.
I plan to take any and all precautions to remove residues. Wire brush all areas, metal clean, metal etch, laquer thinner.
[Re: Leadfoot]
#542598
12/02/09 05:54 PM
12/02/09 05:54 PM
Posts: 6,516 Santa Cruz, California
Lefty
On second thought I too remember factory original primers that had to be sanded off once the paint stripper stopped working... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
What the heck kinda primer was that? ![](/ubbthreads/images/graemlins/penguin-014.gif)
[Re: Lefty]
#542599
12/02/09 06:14 PM
12/02/09 06:14 PM
CYACOP
SW Fla.
Leaded not Unleaded. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Lefty]
#542602
12/02/09 08:12 PM
12/02/09 08:12 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
This the real deal here, Aircraft Remover, Will take everything but the Carburator. It expands with heat so be carefull when you open it. Otherwise you'll be rolling around in the grass with a water hose. ![](/ubbthreads/images/graemlins/stirthepot.gif)
Founder and CEO of the Central Valley Mopar Drag Pack
