Cap and Rotor #542137
12/01/09 04:20 PM
12/01/09 04:20 PM
West Central Indiana
Mr.Runum Offline OP
Mr.Runum  Offline OP
I have an 02 2500 4x4 5.9 gas. MSD ignition, coil, plug wires, but I can not find a MSD/Accel Cap. It eats Auto Zone caps and rotors. What do I use and where do I get it??
Mr.Runum
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
Re: Cap and Rotor [Re: Mr.Runum] #542138
12/01/09 04:48 PM
12/01/09 04:48 PM
Might try extending the rotor blade w solder (out closer to the underside cap terminals) and making sure the rotor center terminal has a bit of tension up against the center button on the cap w some dielectric grease on top of the center rotor tip and on the 8 underside cap terminals all to minimize the gap/spark which may be eroding your terminals and causing your issues especially with the increased fireppower of an MSD. Any spark anywhere other than at the spark plug gap is strickly wasted energy (like a fireworks show) and it burns the contacts (like ign points) further exacerbating the problem by increasing the required voltage.
Re: Cap and Rotor [Re: RapidRobert] #542139
12/01/09 05:26 PM
12/01/09 05:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Get a better brand then the vatozone garbage.
Re: Cap and Rotor [Re: RapidRobert] #542140
12/01/09 07:34 PM
12/01/09 07:34 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
What distributor are you running? What do you mean eating the cap? Electrically with build up or grinding?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Cap and Rotor [Re: sunroofgtx] #542141
12/01/09 11:07 PM
12/01/09 11:07 PM
Mr.Runum Offline OP
Mr.Runum  Offline OP
Electrodes burning away (cap and rotor)plug wires arching. Second set of MSD wires this year and two auto zone, one Napa, best they had caps.
MSD AL6, MSD Blaster Coil, stock cap & rotor, KN Cold Air, shorty headers, factory exhaust, Super Chip, auto, 4x4, 4:10 gears.
At night it looks a lot like Christmas
Mr.Runum
Re: Cap and Rotor [Re: Mr.Runum] #542142
12/01/09 11:09 PM
12/01/09 11:09 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Maybe go back to the stock coil?
I want my fair share
Re: Cap and Rotor [Re: SomeCarGuy] #542143
12/01/09 11:13 PM
12/01/09 11:13 PM
Mr.Runum Offline OP
Mr.Runum  Offline OP
Thats kind of what I was thinking.
Re: Cap and Rotor [Re: Mr.Runum] #542144
12/01/09 11:14 PM
12/01/09 11:14 PM
I bet the MSD box will make the old coil perfrom just fine for you.
Re: Cap and Rotor [Re: RapidRobert] #542145
12/02/09 09:30 AM
12/02/09 09:30 AM
Virginia
JimG Offline
JimG  Offline
Virginia
Might try extending the rotor blade w solder (out closer to the underside cap terminals)...
Robert, I first saw this tip in an old Mopar Action magazine. Richard Ehrenberg said the gap was increased during the emissions era, but he left it at that. What I want to know is, does anyone make a quality rotor with the tighter gap that was (apparently) common "back in the day" (exact date unknown).
Count me among those who extends the tip with solder and then checks for interference using an old distributor I have laying around.
Re: Cap and Rotor [Re: JimG] #542146
12/02/09 10:58 AM
12/02/09 10:58 AM
Hello Jim. Yes I remember that one of the major ign mfr co's did way back (msd or Jacobs maybe??) but I just went ahead & used solder & cut a slot in the side of the cap so I could see the clearance on the dist being used. OT Whenever I run into someone who has JB weld issues I refer them to you since you are "the man" with this stuff . I ran into another dist slot piece & my JB weld had crumbled, I must not be cleaning the slots good enough or maybe my builds put out more power than yours and the torque is slamming it off of there just like a wrecking ball . Any advice from the master . I usually dont get humble very often so take advantage of the opportunity that is being granted to you. Stay in touch. RR
Re: Cap and Rotor [Re: RapidRobert] #542147
12/02/09 12:34 PM
12/02/09 12:34 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
How did you integrate the 6al box into the trucks computer. The trucks computer runs everything from spark timing to fan cooling? I think you have conflicting computer modules. Why did you put on the MSD box? I would also install our FireCore50 wires with the better boots.If you like, give me a call. I think we can work this out.. Thanks
Re: Cap and Rotor [Re: sunroofgtx] #542148
12/02/09 12:53 PM
12/02/09 12:53 PM
Mr.Runum Offline OP
Mr.Runum  Offline OP
The MSD was already on the truck when I bought it, August 06. I added headers and Super Chip. I wondered about that my self, not sure what advantage the MSD would have over stock. I have had it back to the dealer to have the injection timing set. I was told the computer does not care what is on the other side of it, it sends a signal to fire and the MSD does just that.? Truck ran like a scalded dog when I bought it. Not a race truck, just my hunting,fishing,going to work, towing a 30' travel trailer, do everything truck. Re-routed wires last night, changed one out, miss is not as bad. No.1 cyl is down on 25 psi from the rest and header from same cyl runs a little cooler at idel. Will be moving my camper out of the drive way Thurs. Will access to my garage again. Going to do a bleed down to see if maybe have a burnt valve also? Motor does not smoke or make any noises, just misses and give an engine warning of a miss fire.
Mr.Runum
Re: Cap and Rotor [Re: Mr.Runum] #542149
12/02/09 02:58 PM
12/02/09 02:58 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
NAPA here..
Re: Cap and Rotor [Re: RapidRobert] #542150
12/02/09 07:39 PM
12/02/09 07:39 PM
Virginia
JimG Offline
JimG  Offline
Virginia
[quote OT Whenever I run into someone who has JB weld issues I refer them to you since you are "the man" with this stuff . I ran into another dist slot piece & my JB weld had crumbled, I must not be cleaning the slots good enough or maybe my builds put out more power than yours and the torque is slamming it off of there just like a wrecking ball . Any advice from the master . I usually dont get humble very often so take advantage of the opportunity that is being granted to you. Stay in touch. RR
Robert, you scared me away from that stuff (JB Weld) about 6 months ago! I hereby resign my position as "the man". If nominated, I will not run. If elected, I will not serve!
Re: Cap and Rotor [Re: JimG] #542151
12/03/09 11:45 AM
12/03/09 11:45 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
standard ignition products makes a rotor with a longer tip..
Re: Cap and Rotor [Re: Dakota_Don] #542152
12/03/09 12:26 PM
12/03/09 12:26 PM
Mr.Runum Offline OP
Mr.Runum  Offline OP
Where can one purchase one at?
Re: Cap and Rotor [Re: JimG] #542153
12/03/09 03:48 PM
12/03/09 03:48 PM
Spoken like a true protestant. Mr runum alot of parts houses carry "standard" ign brand parts so that'd be my 1st phone call.
