73' 400, balance #541784
12/01/09 12:51 PM
12/01/09 12:51 PM
SD800 Offline OP
SD800  Offline OP
I have a 73' 400, want to know if they are internaly balanced or externaly? do the require a special torque converter. I have a torque conveter out of a 383 I want to put behind this motor
You'll have plenty of time to sleep when your dead, let's go
Re: 73' 400, balance [Re: SD800] #541785
12/01/09 04:30 PM
12/01/09 04:30 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
external... B&M makes a balanced flexplate that will allow you to use any neutral balanced converter with your cast crank.
