Re: Main Bearing Clearance; Am I too tight ??? [Re: TS3303] #540818
12/02/09 05:38 PM
12/02/09 05:38 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
The bearing manufacturers usually use the rule .001 clearance per inch of journal diameter. So in your case, they would want .0026 on the mains, and .0023 on the rods.
Re: Main Bearing Clearance; Am I too tight ??? [Re: todd440] #540819
12/02/09 06:07 PM
12/02/09 06:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
Loser is way better than a tiny bit(.0002) to tight, especaily on bearings and piston clearances I like and use .0025+ on the rods and .003+ on the mains
