Main Bearing Clearance; Am I too tight ???
#540798
11/30/09 01:02 AM
11/30/09 01:02 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
This 451 will be a 10.25:1 street strip motor with a goal of around 500hp, and will likely see between 6000 & 6500 RPM.
413 crank turned down to "B" std.; 400 Block w/ fresh mainline hone.; Cleavite P bearings, std.: ARP main studs.
I don't own a micrometer & bore guage. Plastiguage says I'm between .015 & .020, and is consistant at all journals. Am I too tight? Should I take the crank back to have the main journals polished a bit?
Re: Main Bearing Clearance; Am I too tight ???
[Re: StealthWedge67]
#540801
11/30/09 01:11 AM
11/30/09 01:11 AM
Posts: 43,293 Bend,OR USA
Cab_Burge
I would run .003 and have ran .0038 with no problems on full groove sets. Are the "P" bearings full groove or 3/4 or 1/2 groove? You probally need to have some with a set of inside mikes and outside mikes or a dial bore gauge measure it for you Don't take a chance on anything your not sure of, it could kill you if it fails while racing
[Re: Cab_Burge]
#540802
11/30/09 01:18 AM
11/30/09 01:18 AM
StealthWedge67
Puyallup, WA
Yes, I did mean .0015 & .002. And yes, P bearings are full groove.
I was also hoping to see .0025. You guys seem to be of the same opinion as I. Hmmm. I think I'll take the block & crank back to my machinist & have him measure it. If my plastiguage is accurate, can polishing get me to where I need to be?
[Re: TS3303]
#540804
12/01/09 01:50 AM
12/01/09 01:50 AM
StealthWedge67
Puyallup, WA
I called the machinist today..... He was a bit insulted at even the thought that I would trust a piece of plastigage over his work. He said his "journal" on my motor showed .0023 - .0025 on the mains. "Bring it down here if you want, I'll mic it for ya.... maybe I'll charge ya, maybe I wont, depends on what sort of mood I'm in" was his comment. I don't want to insult the guy, but I also want to be 100% positive that the motor I'm assembling is correct. Hope he doesn't get all pissy with me... Question is, if clearances are a bit under where they should be, what can be done about it?
[Re: Triple Threat]
#540806
12/01/09 02:35 AM
12/01/09 02:35 AM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
if he doesn't respect your fears it's time for another machinist. Tell him you can only afford to do this once and you want to make sure it's right. my machinist is a "confident" sob , but neither of us are afraid to tell each other what we think. Then we go out to the track and have a good time. work is not personal it's professional.
[Re: R70RUNNER]
#540809
12/01/09 09:20 AM
12/01/09 09:20 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
My machinist is just the opposite.If I have any questions he will double and even triple check it.He spent like 2 hours just checking the keepers and springs on my new Stealth heads even though I wasnt going to use them.He just wanted to do it for his own knowledge.A good machinist is priceless.That and his prices are super reasonable.Some Ohio guys here know him and all say the same thing .He is one of the best.Rocky
Chrysler Firepower
#540811
12/01/09 10:00 AM
12/01/09 10:00 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
The present machinist's attitude is unaceptable and you should tell him that. At this time, I would find another competent machinist, tell him to check the work that was done and offer to pay him for the inspection. If it is that tight, there is a good chance it will eat a bearing.
8.30's @3400 lbs
#540812
12/01/09 11:05 AM
12/01/09 11:05 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
guess what , that's his problem , not yours . I have a block here that needs to go to the next overbore and a set of file fit rings that are useless because the guy that assembles the blocks at the shop I USED TO USE didn't check the bosses work ... hourglass bores .0025 OVERSIZE ...
I don't care who does the work ... CHECK IT ... if the guy gets insulted then that's his problem , even the best make mistakes ...
but he does have a point , checking his work with PLASTIGUAGE ...
#540813
12/01/09 12:20 PM
12/01/09 12:20 PM
Posts: 5,080 organ
maximum entropy
organ
i wouldn't be surprised if your machinist is right- plastigage ain't worth a damn anymore, imo. in fact, it's decline is responsible for me running out and getting myself a dial bore gauge. in the olden days, plastgage was different. now it just feels like a piece of wax or some such nonsense.
[Re: B G Racing]
#540815
12/02/09 02:52 PM
12/02/09 02:52 PM
StealthWedge67
Puyallup, WA
Well, chalk one up for the machinist in this case. Just got back from the shop, we torqued up the mains & rods, and measured all the journals.... Clearances at mains were between .0021 & .0023. Rods were all at .0022 or .0023. I'm new at this, and its important to note that prior to machining, I never gave him any specific clearance requests. He said with a performance motor, he shoots for the high side of the bearing manufacturers reccomendations, which is exactly where its all at. I'm satisfied. And its also worth noting that he treated me very well when I showed up for the double-check process. In the words of Emily Litella: Never Mind
#540816
12/02/09 03:08 PM
12/02/09 03:08 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Did he actually mic each or did he plastic gage them?
