Re: 68-70 b-body outer wheelhouses
[Re: hemicar1971]
#53986
02/27/08 01:25 AM
02/27/08 01:25 AM
Posts: 1,039 INDIANA
Paul Jacobs
INDIANA
"I recently ran into major problems trying to use Goodmark's "Authentic Reproduction" Dodge B-Body outer wheelhousings on my 1969 Charger 500" What a joke. Mopar isn't worried that your part wont fit, they just want money from royalties paid by suppliers that want that "Authentic Reproduction" wording on their product. Heck, they probably dont even know what a wheelhouse is ![](/ubbthreads/images/graemlins/biggrin.gif) The AMD stuff I have used is awesome and is a great addition to our hobby.
[Re: a12superbee]
#53989
02/27/08 10:39 PM
02/27/08 10:39 PM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
xs29j8, Thanks for posting all that. Some of us that don't do a car a year would never notice those things until it was too late.
I hope the information does help someone, but this episode cost me a lot of $$$ which Goodmark is so far not stepping up to the plate to reimburse...
In addition to almost $300 for the outer wheelhousings (incl shipping), there is the body shop labor to install & remove the incorrect parts... about $450.
There are other expenses as well, and to fix the problem I had to use a wheelhousing intended for my Six Pack Charger... So now I have to find a replacement for that one.
Here is the used wheelhousing being removed from the '70 quarter panel:
XS
[Re: 70RT Charger]
#53990
02/27/08 10:50 PM
02/27/08 10:50 PM
xs29j8
Fort Worth, Texas
Wow!Thanks for all the info XS.Im already on the list for their quarters.I called AMD today and told them to mark me down for a set of wheelhouses.Somebody replaced the trunk about 10 years ago and still looks good.The pictures of that trunk make me almost want to rip mine out and install the one piece.
I plan to send more pictures to AMD to show the problems encountered with the Goodmark "repro" parts, but I believe that they are going to get them right. Unlike the "Better Than Nothing" vendors, they actually do first First Acticle Inspections and test fits...
They final verdict will be known when the parts that I am getting from them are installed, but so far they have been a great company to work with... anf the trunk floor looks sooooo nice!
It was well packaged also... ![](/ubbthreads/images/graemlins/beer.gif)
XS
[Re: xs29j8]
#53991
03/14/08 07:46 PM
03/14/08 07:46 PM
Posts: 73 Toronto,Canada
wkeggenhoff
Toronto,Canada
can you install the 1 piece trunk floor with quarters still on the car ?
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
[Re: wkeggenhoff]
#53992
03/15/08 01:29 AM
03/15/08 01:29 AM
Yes a one piece trunk floor can be installed with the 1/4's still on.I have done it.On a Charger,it can be done by removing the rear valance panel[which a Charger usually needs anyway],and removing the tailpanel which is actually easy on a Charger since it is welded on top of the 1/4's ends not under like other cars. I have installed the repro outer wheelhouses several times on B bodies.They are a real dissapointment.They look great until you try to fit them and they are way off. They fit much better if you leave the original pinchweld intact at the outer/inner wheelwell seam and splice the new outer about 1/2 inch on the outside of the pinchweld.That way you can adjust the position and don't disturb the original inner to outer pinchweld which is a continuous resistance weld.Plug welding the repro outer to the original inner opens up leakage issues.From what I have seen,AMD's panels all look way better than Goodmarks. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: wkeggenhoff]
#53993
03/25/08 05:13 PM
03/25/08 05:13 PM
OLD318
A better question is:
Can you install or at least "GET" the 1 piece trunk floor from AMD into the trunk with only the trunk lid removed?
or do you "Have" to remove the tailpanel?
Or as another option...
Could you "get" the 1 piece trunk floor (from AMD) into the trunk with the trunk removed and 1 quater panel removed...
or do you have to remove the tailpanel as well?
inquiring minds want to know!!!
![](/ubbthreads/images/graemlins/smile.gif)
[Re: OLD318]
#53994
03/29/08 10:42 AM
03/29/08 10:42 AM
xs29j8
Fort Worth, Texas
Removing the taillight panel is definitely the best way to go, although a "side entry" approach might be possible if some of the backlight area supporting structure was dis-connected.
The picture below should show the problems with that approach...
XS
[Re: xs29j8]
#53999
03/29/08 12:42 PM
03/29/08 12:42 PM
Posts: 368 Jacksonville, Fl
426runner
Jacksonville, Fl
Same work required here. Really slowed down the installation ![](/ubbthreads/images/graemlins/shock.gif) Lip needed to move in- ![](http://www.sandysgarage.com/wk90_e.jpg) Lip moved in- ![](http://www.sandysgarage.com/wk90_f.jpg) Lip needed to move up- ![](http://www.sandysgarage.com/wk90_g.jpg) Lip moved up- Pie cuts required- If I had it to do again I would leave the original lip attached to the car and splice in just enough of the new outerhousing as I needed, aligning the lip in the right place from the start. ![](/ubbthreads/images/graemlins/sawzall-smiley.gif)
Later, Sandy
'70 HEMI Road Runner B5/B5, 4 spd
"Sandy's Garage" on Facebook
[Re: xs29j8]
#54001
04/04/08 09:58 AM
04/04/08 09:58 AM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
Another view...
Looks like the AMD outer wheel houses are going to have the foward flange on it according to the pics.
[Re: xs29j8]
#54003
07/18/08 06:40 PM
07/18/08 06:40 PM
70RT Charger
eastern,Ky
Here is another angle showing the mis-match before the black color was removed by plastic media blasting...
XS
I got tired of waiting on AMD for my wheelhouses so I ordered a set from the paddock and they almost look like the originals,they look nothing like ones you show but they still look like they are going to fit crappy.
