Pick my parts #539704
11/28/09 11:05 PM
11/28/09 11:05 PM
A Happy Place, A Happy Place, ...
57Plymouth Offline OP
I have a Dart Sport that I plan to get around to building one of these days. I have a 318 out of my truck that I will likely use to make it a cruiser. The question I have is what tranny to use. I have the 727 that was with the 318 when I pulled it. They were the original engine and tranny in my 1980 truck. I also have a short tail shaft 904. Both transmissions need to be rebuilt. Should I use the short tailshaft 904 or the long tailshaft 727?
I need to know so I can sell the other to clear up some space in my garage. I want to keep the one that is best for the Dart Sport in the future.
Virtus Junxit Mors Non Separabit
Re: Pick my parts [Re: 57Plymouth] #539705
11/28/09 11:18 PM
11/28/09 11:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Stick with the 727. better stronger trans. Plus you already have the correct flexplate & converter.
Re: Pick my parts [Re: stumpy] #539706
11/29/09 12:08 AM
11/29/09 12:08 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
If the Dart Sport is an original 904 car, you will have to shorten/rebalance the driveshaft to use it with a 727.
Re: Pick my parts [Re: Reggie] #539707
11/29/09 01:19 AM
11/29/09 01:19 AM
the 904 will be a better match to the smaller 318. the 727 will be worth much more & will put some funds in your pocket
Re: Pick my parts [Re: Reggie] #539708
11/29/09 03:36 PM
11/29/09 03:36 PM
The car was a /6 car. So it had to be a 904. I'm not planning on a huge motor. Just a 318 with a small cam and an intake and headers. No real big power, so I know the 904 will work for my application. I have both transmissions and they both need a rebuild. Is the value of the 727 that much more than the 904 that it is wiser to sell the stronger transmission for my mild cruiser?
Keep in mind that I have to finish my wife's car, and re-restore my 57 Plymouth before I think about this Dart Sport. I'm just going to drop them into the car to get them out of my way for the next decade or so...
Re: Pick my parts [Re: 57Plymouth] #539709
11/29/09 04:39 PM
11/29/09 04:39 PM
yes
