Page 2 of 4 1 2 3 4
Re: AAR vs. T/A Hood Springs [Re: cataclysm80] #53915
03/02/08 09:15 PM
03/02/08 09:15 PM
i have both springs in stock
Re: AAR vs. T/A Hood Springs #53916
03/03/08 09:56 AM
03/03/08 09:56 AM
cataclysm80 Offline OP
I've looked around several parts distributors web sites, and all have the springs mislabeled. I'm pretty sure the manufacturer is the one labeling them wrong and passing it on to the distributors who are unaware of the difference.
Tom, if you have it, would you PM me the manufacturers contact info?
Tav
Re: AAR vs. T/A Hood Springs [Re: cataclysm80] #53917
03/03/08 05:38 PM
03/03/08 05:38 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
The only diff that I can see in my originals and the ones tomr has pictured is that my original ends do not come back as close to the coil at the ones in the pics. They look like the ones in the YO pic.
Re: AAR vs. T/A Hood Springs [Re: fastmark] #53918
07/29/08 10:17 AM
07/29/08 10:17 AM
Some people have been asking me about this, so here's a bump to the top so it's easier to find.
I've contacted a few distributors about this issue, and spoke with a guy who claims to be the manufacturer. To my knowledge, nothing has been changed yet and they are still being sold mislabeled. I'm still working on getting this issue resolved.
Tav
Re: AAR vs. T/A Hood Springs [Re: cataclysm80] #53919
07/29/08 04:02 PM
07/29/08 04:02 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Does anyone have any experience with a warped hood going back to normal by removing the springs? I am about sick enough of my warpage to use a prop rod.
Re: AAR vs. T/A Hood Springs [Re: PAINT IT BLACK] #53920
07/29/08 04:15 PM
07/29/08 04:15 PM
, PA
sleepyhead416 Offline
, PA
I bought my AAR in 71 The dealer installed hood pins in the middle (alongsides) of hood they sold 13 all had them this was not the cure. Tomsic Chrysler Plymouth was dealer. My car sat for 15years with springs on took them off hood flaten right out.
Re: AAR vs. T/A Hood Springs [Re: PAINT IT BLACK] #53921
07/29/08 06:00 PM
07/29/08 06:00 PM
Yes, My repro AAR hood had repro TA springs on it for about a year and it got pretty warped. (that's when I found out about having the wrong springs) Took em off and been using a prop rod ever since. Hood flattened out over the coarse of a month or so. Heat helps it flatten out, if your in a hurry you could park it in the sun. I've also heard of a guy putting sand bags on the hood cause the weight helps too, but it's not neccesary if your patient.
Another note: if you don't like the prop rod look you can bend a solid bar to replace the spring. Just make it so it hooks around the same spots the spring would and make it the proper length to hold the hood in the open position. Should only need it on one side. Just open the hood and install the bar, same procedure as a prop rod, but it doesn't take up as much space in the back seat. You can even paint it to match your car, and few people will ever notice the springs aren't there. It's not up in your way like a prop rod. JUST ONE REALLY IMPORTANT THING! DON'T FORGET IT'S THERE AND TRY TO CLOSE THE HOOD! (Crack!! )
Tav
Re: AAR vs. T/A Hood Springs [Re: cataclysm80] #53922
07/29/08 06:16 PM
07/29/08 06:16 PM
Houston Texas
Houston Texas
Thanks!
Re: AAR vs. T/A Hood Springs [Re: PAINT IT BLACK] #53923
07/29/08 11:32 PM
07/29/08 11:32 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Tav, so when T/A owners order a hood spring an AAR spring is sent instead - and vise versa & in every case? If so, major screw up and all your perseverance has paid off & in a big way 'cause there's gotta be alot of owners that read this and can now have all they need - all provided here & by you & the other great members - to measure the part and visually examine its the correct piece or provide exact measurements & coil count to their supplier before its sent. Great detective work & your a great asset here & for alot of reasons.
Re: AAR vs. T/A Hood Springs [Re: ebodyseast] #53924
07/30/08 07:43 AM
07/30/08 07:43 AM
Yes, That's correct.
Thank You.
Tav
Re: AAR vs. T/A Hood Springs [Re: cataclysm80] #53925
07/30/08 11:29 PM
07/30/08 11:29 PM
NW/Indiana - Chi town
ricomondo Offline
ricomondo  Offline
Hey Tav, Im surprised that repop hood warped . I thought the repops were supposed to re-enforced along the sides to prevent the warping problem. Am I correct on this? Maybe depends on who manufactured the hood?
GY3 71 Demon 340
Re: AAR vs. T/A Hood Springs [Re: ricomondo] #53926
07/31/08 07:52 PM
07/31/08 07:52 PM
Yes, my repop AAR hood does have extra reinforcing, but I guess it just wasn't enough to hold up against the stronger TA springs. I got the hood from Year One, probably about 5 years ago now.
Hoping not to have any warpage problems with my new ASC&P TA hood!
Tav
Re: AAR vs. T/A Hood Springs [Re: cataclysm80] #53927
07/31/08 08:11 PM
07/31/08 08:11 PM
I guess while I'm on the topic of springs, I'll post the data for steel hood springs also.
barracuda: 24 coils, .215 spring thickness (with paint), 1 3/4 outside diameter, 5 1/8 long (without hooks)
challenger: 22 coils, .240 spring thickness (with paint), 1 15/16 outside diameter, 5 1/4 long (without hooks)
Tav
Found this in another thread and thought I'd post it here also since it's relevant.
Barnabas_Kriss wrote...
Actually for the steel hoods, there are two kinds of springs, I researched this in the 70-71 factory parts book, and confirmed it on cars I owned/parted. One is 23 coils, used on 70 cuda/barracuda only. The other one is 18 coils, (wound from a thicker wire) used on 70 challengers, and all 71-74 E-bodies. This applies to all steel hoods (flat/rally/shaker).
Perhaps we've counted our coils differently, It can be tricky deciding if you should count the first and last ones with the hooks on them. Anyway, I thought I'd let everyone know this this needs looked into just a little more, and maybe a picture posted here showing a comparison.
Tav
Re: AAR vs. T/A Hood Springs [Re: cataclysm80] #53928
07/31/08 08:32 PM
07/31/08 08:32 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Tav
How can the springs warp the hood?
NMCA NSS 67 Coronet
Re: AAR vs. T/A Hood Springs [Re: Barry70GTX] #53929
07/31/08 09:16 PM
07/31/08 09:16 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Remember that the springs are stretched while the hood is closed, therefore exerting pressure from the spring anchor point to where it attaches on the hood.
The spring assists in the opening of the hood as the spring compresses while the hood is open.
Make any sense?
Frank
Re: AAR vs. T/A Hood Springs [Re: cataclysm80] #53930
07/31/08 10:10 PM
07/31/08 10:10 PM
Ohio
B5TA Offline
B5TA  Offline
Ohio
Ok , I'm going to say it 1 more time , just like I have said it for the past 35years, LEAVE THOSE STINKING HOOD SPRINGS OFF! unless you want to ruin your hood.. What it does is exactly like the above post says, it puts stress/ pressure on the front ( leading edge ) of the hinge when it is closed. That stress then weakens the fiberglass which thus causes the WARPAGE. If you show your car then I would open the hood and then install the springs, then take them back off before closing the hood. But myself I would use 2 prop rods at the front. Kev
Re: AAR vs. T/A Hood Springs [Re: Chi_Town_Runner] #53931
07/31/08 10:19 PM
07/31/08 10:19 PM
Barry70GTX Offline
Barry70GTX  Offline
Make any sense?
Frank
And how much spring pressure would that be?
NMCA NSS 67 Coronet
Re: AAR vs. T/A Hood Springs [Re: Barry70GTX] #53932
08/01/08 03:16 PM
08/01/08 03:16 PM
I couldn't tell you how many lbs of pressure there would be but as an example...
next time you see a hood off a car and the springs/hinges are still mounted, try to push the hood spring down to the open position.
I say while it's on the car because I don't think you would be able to open the hood hinge in your bare hands while it was off the car.
You could also mount it in a vice.
The point being.....how much pressure?
Quite a bit.
Better yet...remove the sping from the hood hinge and try to stretch the spring.
Frank
Re: AAR vs. T/A Hood Springs [Re: Chi_Town_Runner] #53933
08/01/08 03:53 PM
08/01/08 03:53 PM
Barry70GTX Offline
Barry70GTX  Offline
Sure there is plenty of pressure with the hood in the up position.
How much is there in the down position?
NMCA NSS 67 Coronet
Re: AAR vs. T/A Hood Springs [Re: Barry70GTX] #53934
08/01/08 06:34 PM
08/01/08 06:34 PM
The pressure is greatest when the hood is "CLOSED"
The spring pressure is what assists in OPENING the hood. Once the hood is open there is NO PRESSURE exerted on the hood. Thats why the hoods warp, from the pressure of the spring pushing up on the hood while it's CLOSED.
Frank
Page 2 of 4 1 2 3 4
