PCV hose question #539089
11/28/09 01:38 PM
11/28/09 01:38 PM
dark side of the moon
Dougsmopars Offline OP
On 68 BB did they use any type of clamp on the pcv hose? If they did what type clamp? Thanks in advance
Re: PCV hose question [Re: Dougsmopars] #539090
11/28/09 05:45 PM
11/28/09 05:45 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
pcv hose, No.
power brake booster hose ( same hose btw) Yes
Re: PCV hose question [Re: gtx6970] #539091
11/29/09 08:50 AM
11/29/09 08:50 AM
I agree Bill. The factory service manual shows this as well. I was actually questioned by an AACA judge one day as to why all of my hoses inside the engine compartment had clamps on them with the exception of the PCV hose. His thought that should the engine backfire, the hose would blow off causing a problem. I agreed with his logic but showed him in the factory manual that it was the way that Chrysler did things.
