Re: AAR vs. T/A Hood Springs
[Re: B5TA]
#53899
02/17/08 10:53 PM
02/17/08 10:53 PM
Posts: 6,381 Abilene, Texas
fastmark
Abilene, Texas
Unless you want them for "Showing" I'd leave those puppies off!! Make a prop rod or two and save your hood. IMHO
That's true. The factory kept replacing the hoods under warrantee because they bowed in the middle. Finally the factory came up with the fix. Take the hinges off and use a prop rod. I did that to mine and it flattened right back out to match the fenders. My hood hinges for my AAR have 33 coils.
[Re: mccannix]
#53901
02/18/08 12:51 PM
02/18/08 12:51 PM
I bought some reproduction springs, got to look at my part number I got.. anyone have a pic of the underside of an original, my hood looks like it was made with fiberglass matting. not very neat in appearence. I seen some repros and they look real nice on the inderside.
[Re: fastmark]
#53904
02/18/08 11:30 PM
02/18/08 11:30 PM
Posts: 5,817 NJ
moparply
NJ
I have a set of original AAR hood springs. They measure 5 1/2" long, 33 coils, 1 5/16 OD, the spring thickness measured with a micrometer is .166 . I have a set of NOS TA hood springs, purchased from Chrysler in the 70's, no dealer sticker but I know who bought them. They measure 6 1/2" long, 36 coils, 1 5/16 OD, the spring thickness is .180 . The spring thickness is more on the TA springs I have, not sure if the over the counter springs were the same as the production line springs, they are gold cad plated. The hooks are also different between the two springs! These springs are unique to just the AAR and the TA.
[Re: cataclysm80]
#53910
03/01/08 10:51 PM
03/01/08 10:51 PM
fastmark
Abilene, Texas
Here's the pic of AAR springs from the year one website. Is THIS what AAR springs are actually supposed to look like?
Tav
Those springs are not correct. The pic is just generic.
[Re: cataclysm80]
#53912
03/02/08 04:35 PM
03/02/08 04:35 PM
