Re: AAR vs. T/A Hood Springs
[Re: cataclysm80]
#53915
03/02/08 09:15 PM
03/02/08 09:15 PM
i have both springs in stock
[Re: fastmark]
#53918
07/29/08 10:17 AM
07/29/08 10:17 AM
Posts: 4,165 Florida
cataclysm80
Some people have been asking me about this, so here's a bump to the top so it's easier to find. I've contacted a few distributors about this issue, and spoke with a guy who claims to be the manufacturer. To my knowledge, nothing has been changed yet and they are still being sold mislabeled. I'm still working on getting this issue resolved. Tav
[Re: PAINT IT BLACK]
#53920
07/29/08 04:15 PM
07/29/08 04:15 PM
Posts: 1,990 , PA
sleepyhead416
, PA
I bought my AAR in 71 The dealer installed hood pins in the middle (alongsides) of hood they sold 13 all had them this was not the cure. Tomsic Chrysler Plymouth was dealer. My car sat for 15years with springs on took them off hood flaten right out.
#53921
07/29/08 06:00 PM
07/29/08 06:00 PM
cataclysm80
Yes, My repro AAR hood had repro TA springs on it for about a year and it got pretty warped. (that's when I found out about having the wrong springs) Took em off and been using a prop rod ever since. Hood flattened out over the coarse of a month or so. Heat helps it flatten out, if your in a hurry you could park it in the sun. I've also heard of a guy putting sand bags on the hood cause the weight helps too, but it's not neccesary if your patient. Another note: if you don't like the prop rod look you can bend a solid bar to replace the spring. Just make it so it hooks around the same spots the spring would and make it the proper length to hold the hood in the open position. Should only need it on one side. Just open the hood and install the bar, same procedure as a prop rod, but it doesn't take up as much space in the back seat. You can even paint it to match your car, and few people will ever notice the springs aren't there. It's not up in your way like a prop rod. JUST ONE REALLY IMPORTANT THING! DON'T FORGET IT'S THERE AND TRY TO CLOSE THE HOOD! (Crack!! ) Tav
[Re: cataclysm80]
#53925
07/30/08 11:29 PM
07/30/08 11:29 PM
Posts: 2,058 NW/Indiana - Chi town
ricomondo
Hey Tav, Im surprised that repop hood warped . I thought the repops were supposed to re-enforced along the sides to prevent the warping problem. Am I correct on this? Maybe depends on who manufactured the hood?
GY3 71 Demon 340
[Re: cataclysm80]
#53927
07/31/08 08:11 PM
07/31/08 08:11 PM
cataclysm80
I guess while I'm on the topic of springs, I'll post the data for steel hood springs also.
barracuda: 24 coils, .215 spring thickness (with paint), 1 3/4 outside diameter, 5 1/8 long (without hooks)
challenger: 22 coils, .240 spring thickness (with paint), 1 15/16 outside diameter, 5 1/4 long (without hooks)
Tav
Found this in another thread and thought I'd post it here also since it's relevant.
Barnabas_Kriss wrote...
Actually for the steel hoods, there are two kinds of springs, I researched this in the 70-71 factory parts book, and confirmed it on cars I owned/parted. One is 23 coils, used on 70 cuda/barracuda only. The other one is 18 coils, (wound from a thicker wire) used on 70 challengers, and all 71-74 E-bodies. This applies to all steel hoods (flat/rally/shaker).
Perhaps we've counted our coils differently, It can be tricky deciding if you should count the first and last ones with the hooks on them. Anyway, I thought I'd let everyone know this this needs looked into just a little more, and maybe a picture posted here showing a comparison.
Tav
[Re: Barry70GTX]
#53929
07/31/08 09:16 PM
07/31/08 09:16 PM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
How can the springs warp the hood?
Remember that the springs are stretched while the hood is closed, therefore exerting pressure from the spring anchor point to where it attaches on the hood. The spring assists in the opening of the hood as the spring compresses while the hood is open.
Make any sense? Frank
[Re: Barry70GTX]
#53932
08/01/08 03:16 PM
08/01/08 03:16 PM
Chi_Town_Runner
I couldn't tell you how many lbs of pressure there would be but as an example... next time you see a hood off a car and the springs/hinges are still mounted, try to push the hood spring down to the open position. I say while it's on the car because I don't think you would be able to open the hood hinge in your bare hands while it was off the car. You could also mount it in a vice. The point being.....how much pressure? Quite a bit. Better yet...remove the sping from the hood hinge and try to stretch the spring. Frank
[Re: Barry70GTX]
#53934
08/01/08 06:34 PM
08/01/08 06:34 PM
Chi_Town_Runner
The pressure is greatest when the hood is "CLOSED" The spring pressure is what assists in OPENING the hood. Once the hood is open there is NO PRESSURE exerted on the hood. Thats why the hoods warp, from the pressure of the spring pushing up on the hood while it's CLOSED. Frank
