Re: How can I duplicate textured finish on air cleaners?
[Re: Mike H]
#53793
02/13/08 11:43 AM
02/13/08 11:43 AM
Posts: 1,546 Leetonia, OH
R6T8net
Leetonia, OH
Set that baby out in the sun for a while and get it good an hot and then shoot it with the texture paint
"Who is John Galt?"
68 Coronet RT LL1 Auto 70 Duster 340 (yea right) FE5 4 SPD, 11.86 @ 114 MPH so far 01 2500 Quad Cab 4x4 Cummins
[Re: AdamR]
#53795
02/13/08 01:03 PM
02/13/08 01:03 PM
Posts: 1,131 Kent, WA
triple_green
Kent, WA
I use the krinkle finish product and force dry with a hairdryer...it brings out the krinkle more prominently.
3X
68 Charger, 383 HP console auto, spring green, stock restoration
[Re: Mike H]
#53796
02/13/08 01:27 PM
02/13/08 01:27 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Rustoleum actually has a rattle can of "textured black". It is pretty darn close.
This is the land of the free
because of the brave
[Re: 4BBodies]
#53802
03/29/09 12:34 PM
03/29/09 12:34 PM
Posts: 1,947 Edmonton , Alberta , Canada
stwheels
This trick helps the quality of spray for ANY spray can style paint. Shake the can vigorously for several minutes !!! Next place the can in a bowl of hot, out of the tap, water. The water should be hot to the touch but not scalding. It only needs to sit in the water for a minute or so. The paint will spray so nicely you'd swear you were using a spray gun. If you don't feel comfortable putting a can of paint in hot water you could also place the can on a heat register while the furnace is running. The whole idea is to give the can a bit more internal pressure. But remember to shake the can for several minutes before spraying no matter what. Lord knows how long it's been sitting on a shelve or in a box before you bought it.
Doug Lepak
