LONG AWAITED 4 SPEED ALUMINUM CASE PICS! #536
06/03/03 10:26 AM
06/03/03 10:26 AM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #537
06/03/03 10:32 AM
06/03/03 10:32 AM
Details please..!!!
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! #538
06/03/03 10:37 AM
06/03/03 10:37 AM
Parkersburg, WV.
K
Keith_M Offline
super gas
Keith_M  Offline
super gas
K
Parkersburg, WV.
I saw them at Classics. Awesome..I will be getting one...
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! #539
06/03/03 10:39 AM
06/03/03 10:39 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Main case weighs just 14 lbs. vs. 36 lbs. in cast iron.
A Body tail weighs 6 lbs. vs. 18 lbs. in cast iron.
'66-'69 B Body tail weighs 8 lbs. vs. 21 lbs. in cast iron.
'70 - '74 B / E Body tail weighs 8 lbs. vs. 21 lbs. in cast iron.
Sidecover weighs 2 lbs. vs. 5 lbs. in cast iron. It has extra ribbing inside.
Main case countershaft bore is already bushed.
Sidecover bores are bushed as well.
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #540
06/03/03 10:49 AM
06/03/03 10:49 AM
VA
E
Ed_Devinney Offline
super gas
Ed_Devinney  Offline
super gas
E
VA
Hmmm, very interesting indeed. I'm trying to figure out what to do for a trans next winter, bite the bullet and go Tremec TKO or rebuild the 833... What sort of cost are we talking here?
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: Ed_Devinney] #541
06/03/03 10:52 AM
06/03/03 10:52 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Ed,
Main case ready to go. $250.00
Tailhousing, ready to go $250.00
Sidecover $75.00
Buy the whole set $550.00
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #542
06/03/03 11:11 AM
06/03/03 11:11 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
bump
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #543
06/03/03 11:19 AM
06/03/03 11:19 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
VERY cool. Can I put my Hemi 4speed guts in it? I have a low mileage, resto'd Hemi 4 gear form a 69 440-6 RR but am putting it in an E body.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: 71TA] #544
06/03/03 11:25 AM
06/03/03 11:25 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
71TA,
They take all the factory internals! They use all factory seals, gaskets and hardware. You can put your guts into it. We are making cases in both 307 and 308 front bearings to fit every application.
Jamie
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #545
06/03/03 11:34 AM
06/03/03 11:34 AM
Parkersburg, WV.
K
Keith_M Offline
super gas
Keith_M  Offline
super gas
K
Parkersburg, WV.
I was also planning on swapping in my 18 spline internals. I have purchased alot of parts from Jamie, excellent stuff and quick delivery. 4 speed linkages and so on.. He isn't shy about offering advice or help either...great guy.
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #546
06/03/03 11:54 AM
06/03/03 11:54 AM
AndyF Online content
AndyF  Online Content
That looks great. Great product idea! I spent more than a few hours working with a friend of mine to bush a factory aluminum case. When we got all done we still didn't have anything that worked due to the number of casting flaws in the original housing. If you're going to run a four speed, then this has to be something to check out.
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: Keith_M] #547
06/03/03 11:56 AM
06/03/03 11:56 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Keith,
Thanks for the kind words,
Jamie
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #548
06/03/03 12:15 PM
06/03/03 12:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
jamie , looks good .
a few questions , is that B body shift mount a machined piece like the e body or is that a stocker cast piece you happen to have ?
had you put any thought or effort into replacing the roller bearings the factory used with a taper roller bearing ? i can see one stumbling block , but i haven't made the measuremments yet to see if parts from a T5 can be retro fitted between the mainshaft and the iput shaft .
also , have you assembled on and had it installed behind a high HP engine in a racing atmosphere ?
my need is for stock appearing racing and if it can handle a wide open throttle shift with a 550 plus HP engine its of little good to me ...
unfortunately the stock appearing guys as well as resto anal freaks will have to grind off your logos ...
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #549
06/03/03 12:25 PM
06/03/03 12:25 PM
VA
E
Ed_Devinney Offline
super gas
Ed_Devinney  Offline
super gas
E
VA
Ed,
Sidecover $75.00
Not bad, folks - it's cheaper than steak on a per-pound basis :-)
I already have an aluminum tail housing and have to pull the trans to fix the tailshaft busing. Have to check how much work to rebuild the trans and go from there...
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: Ed_Devinney] #550
06/03/03 12:35 PM
06/03/03 12:35 PM
COOL. Jamie, do you have a price list or catalog i could look at for ideas? and is it online? How much power can these take?and whats the threshhold gain over stock?
nice looking peice!!!
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! #551
06/03/03 12:46 PM
06/03/03 12:46 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
The catalog is not on-line. e-mail me your address and I can mail you one.
fourspd@ptd.net
Thanks,
Jamie
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JohnRR] #552
06/03/03 12:51 PM
06/03/03 12:51 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
JohnRR,
I did explore the tapered roller bearing idea. This would make a special bearing retainer necessary then. We were striving to use all factory type hardware. That would minimize the cost of retrofitting the aluminum cases to your application. The factory 308 bearing is a high load bearing so I don't see the retrofit to be worth it. We have tested them and I feel that they should hold up fine to whatever you can throw at them within reason.
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #553
06/03/03 01:16 PM
06/03/03 01:16 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
bump1
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! [Re: JamiePasson] #554
06/03/03 01:28 PM
06/03/03 01:28 PM
This ought to shed a few pounds on those F.A.S.T. cars!
Re: LONG AWAITED 4 SPEED ALUMINUM CASE PICS! #555
06/03/03 01:41 PM
06/03/03 01:41 PM
Uppsala, Sweden
Satanized_68 Offline
Uppsala, Sweden
That makes me really wanna go back to 4-speeds!
Shed some weight, retain the strength.
Great work!
Getting closer... <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
