How can I duplicate textured finish on air cleaners? #53791
02/13/08 10:47 AM
02/13/08 10:47 AM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
Does anyone know how to create the textured finish on air cleaners? Car is a 70 Challenger
Re: How can I duplicate textured finish on air cleaners? [Re: Mike H] #53792
02/13/08 10:51 AM
02/13/08 10:51 AM
West coast
71Beelover Offline
71Beelover  Offline
West coast
They sell the Krinkle finish in a can. One word of advise with this stuff....it works best in warmer temps. If its too cold it will not krinkle evenly.
Here is a brand that Eastwood sell..
http://www.eastwoodco.com/jump.jsp?itemID=106&itemType=PRODUCT
Re: How can I duplicate textured finish on air cleaners? [Re: Mike H] #53793
02/13/08 11:43 AM
02/13/08 11:43 AM
Leetonia, OH
R6T8net Offline
R6T8net  Offline
Leetonia, OH
Set that baby out in the sun for a while and get it good an hot and then shoot it with the texture paint
"Who is John Galt?"
68 Coronet RT LL1 Auto
70 Duster 340 (yea right) FE5 4 SPD, 11.86 @ 114 MPH so far
01 2500 Quad Cab 4x4 Cummins
Re: How can I duplicate textured finish on air cleaners [Re: R6T8net] #53794
02/13/08 12:44 PM
02/13/08 12:44 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Use a heat gun to make it wrinkle.
Re: How can I duplicate textured finish on air cleaners [Re: AdamR] #53795
02/13/08 01:03 PM
02/13/08 01:03 PM
Kent, WA
triple_green Offline
Kent, WA
I use the krinkle finish product and force dry with a hairdryer...it brings out the krinkle more prominently.
3X
68 Charger, 383 HP console auto, spring green, stock restoration
Re: How can I duplicate textured finish on air cleaners? [Re: Mike H] #53796
02/13/08 01:27 PM
02/13/08 01:27 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Rustoleum actually has a rattle can of "textured black". It is pretty darn close.
This is the land of the free because of the brave
Re: How can I duplicate textured finish on air cleaners? [Re: rbstroker] #53797
02/13/08 01:45 PM
02/13/08 01:45 PM
Colorado
CuriousYella70 Offline
Colorado
Everyone I know has used Krylons wrinkle black finish Or i've heard Harley Davidsons wrinkle black is dead on but good luck spraying it, i bought four cans and not one sprayed it decent enough! It's true, you have to have a warm day!
Personally, after i primered it i sprayed it with a heavy coat and slid it into the oven--put it on 400 degrees and after only a minute or two it wrinkled right up. You can do it in the sun but you may get mixed results, an oven gets even results all of the way around
Re: How can I duplicate textured finish on air cleaners [Re: Mike H] #53798
02/13/08 02:41 PM
02/13/08 02:41 PM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
I took mine to a local powder coater for $65, after 3 years it still looks new.
Re: How can I duplicate textured finish on air cleaners [Re: JS29] #53799
02/13/08 06:21 PM
02/13/08 06:21 PM
East of nowhere
41hemi Offline
Wife thinks I am Crazy!
41hemi  Offline
East of nowhere
I've used Krylon for years with good results. Both air cleaner and valve cover on the /6 are Krylon. It's tough stuff.
Re: How can I duplicate textured finish on air cleaners [Re: 41hemi] #53800
02/13/08 07:46 PM
02/13/08 07:46 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
The Krylon is great stuff. But to get it right without the oven or hair dryer which I've never tried personally, you got to do it in the direct sunlight with at least a 80 degree day. Let it sit in the sun and get super hot to the touch and then spray it very evan. Too much or too little one place or the other will cause the wrinkle effect to be different than the rest of the part. Follow those simple instructions and you won't be able to tell the difference from an orignal job. Its that good.
Re: How can I duplicate textured finish on air cleaners [Re: JS29] #53801
03/29/09 10:19 AM
03/29/09 10:19 AM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
VHT High Temp wrinkle black with a heat gun. Awesome results, about $11.
Re: How can I duplicate textured finish on air cleaners [Re: 4BBodies] #53802
03/29/09 12:34 PM
03/29/09 12:34 PM
Edmonton , Alberta , Canada
stwheels Offline
stwheels  Offline
This trick helps the quality of spray for ANY spray can style paint.
Shake the can vigorously for several minutes !!!
Next place the can in a bowl of hot, out of the tap, water. The water should be hot to the touch but not scalding. It only needs to sit in the water for a minute or so. The paint will spray so nicely you'd swear you were using a spray gun.
If you don't feel comfortable putting a can of paint in hot water you could also place the can on a heat register while the furnace is running. The whole idea is to give the can a bit more internal pressure. But remember to shake the can for several minutes before spraying no matter what. Lord knows how long it's been sitting on a shelve or in a box before you bought it.
Doug Lepak
Re: How can I duplicate textured finish on air cleaners [Re: stwheels] #53803
03/29/09 01:02 PM
03/29/09 01:02 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
The hot water trick works well, but I just sit the spray can in front of my warm air furnace. Gets quite warm! Spray on 2 heavy, almost runny coats (but do NOT run it) and wait about 10 minutes. THEN start the heat gun, the wrinkle spreads like a virus. Too cool!
