5/64 vs 1/16 ring thickness #537364
11/26/09 04:25 PM
11/26/09 04:25 PM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
This is probably some real basic thing that I just don't know. But what is the advantage/disadvantage to using pistons that take compression rings that are 5/64 versus 1/16.
Re: 5/64 vs 1/16 ring thickness [Re: Chilort] #537365
11/26/09 04:58 PM
11/26/09 04:58 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
the 1/16 cause less drag.
Re: 5/64 vs 1/16 ring thickness [Re: Dodgem] #537366
11/27/09 11:12 AM
11/27/09 11:12 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
That's it?
Re: 5/64 vs 1/16 ring thickness [Re: Chilort] #537367
11/27/09 12:28 PM
11/27/09 12:28 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
The 5/64 is pretty much the standard OEM style ring and would probably have an edge in long term durability (100k miles)over the 1/16. For most of us, it does not matter.
Re: 5/64 vs 1/16 ring thickness [Re: Lee446] #537368
11/27/09 12:46 PM
11/27/09 12:46 PM
for a performance app if the piston you want is available w 1/16 grooves you will have far less drag & more performance.
