Page 6 of 6 1 2 3 4 5 6
Re: PRH pump gas 572 dyno results [Re: BDS871Cuda] #534394
11/28/09 11:17 AM
11/28/09 11:17 AM
Ontario,Canada
firefighter3931 Offline OP
Ontario,Canada
I guess we all call our big cars (Tank)!
Keeping everything under the stock hood is cool.
My Jason Line (Line Performance) built 440 ran a
M-1 intake, and pushed my 4000 lb. pig or (tank)
to 11.16 at 118. I was thinking real hard about
a tiny shot of juice
Wow, that's impressive performance for a 440 !
I'd like to hear more about your "tank"
Ron
Re: PRH pump gas 572 dyno results [Re: firefighter3931] #534395
11/29/09 01:05 PM
11/29/09 01:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
something to keep in mind when comparing the 440-2D vs the 337 in this type of build is cost.
the 2D is $350+ before you have the ports opened to MW size, or do any plenum mods.
Indy gets $100 for the CNC MW job, so now you have a $450+ manifold.
on the 2D tested here, i opened the ports to MW size and trimmed down the plenum divider height.
the 337 was run right OOTB(other than grinding down the bottoms of the end rails to clear the attaching bolts of the ICH valley plate), and is only like $229.......if you can find one.
and in all fairness, the port exits on that intake were pretty small for "MW" sized runners, so some gains might be made if the intake were tweeked a bit.
one could probably have that done and still have it cost less than a std port sized 440-2D($350).
Ron can tell you, i was totally a skeptic about the 337 manifold before we started doing some back to back tests.
but for this type of build, its really a pretty good piece.
if these became available again, they would be my #1 choice for the pump gas/street type stroker builds where a MW sized intake would be preferred.
something like the 505 that TonyS built with the CNC stealth heads.
505 dyno thread
take that motor, open the heads to MW size and run the 337 intake, and i think it would be reasonable to expect to see somewhere near a 20-30hp gain, with very little loss of low speed response.
Re: PRH pump gas 572 dyno results [Re: firefighter3931] #534396
11/29/09 01:17 PM
11/29/09 01:17 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
how tall is that 337 intake?
Mopar Performance
Re: PRH pump gas 572 dyno results [Re: fast68plymouth] #534397
11/29/09 01:33 PM
11/29/09 01:33 PM
AndyF Offline
AndyF  Offline
505 dyno thread
I agree with all the points. The low cost is one reason why I decided to try the intake. I only paid $200 at the local dealer for my first 337 intake. It was easy to swap on the dyno so I used it on a few motors with good results. The built in valley is a hassle with Indy heads, but it is great when using standard heads that are opened up to a MW opening. The low height is a big plus when trying to fit in under a flat hood.
That intake just flat out works on some combinations. I'm sure it has its limits but it also seem to have a nice sweet spot that matches up with a lot of typical combinations.
Re: PRH pump gas 572 dyno results [Re: fast68plymouth] #534398
11/29/09 06:56 PM
11/29/09 06:56 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i use a 337 on my 580".it does very good,considering you can close a stock hood with it.on my motor i gave up about 70 horsepower to a 440-3 w/ dominator.
the ports are small for a max wedge.it took alot of work to open them up to the ports in my 572-13,s.i'm getting ready to try a 337 on my 500".i will try alot of manifold combos,and post the results.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: PRH pump gas 572 dyno results [Re: Old School] #534399
11/30/09 10:35 PM
11/30/09 10:35 PM
Ontario,Canada
Ontario,Canada
Just a couple of pics to post up ;
Diamond Racing 34cc dished pistons
Ron
Re: PRH pump gas 572 dyno results [Re: firefighter3931] #534400
11/30/09 10:37 PM
11/30/09 10:37 PM
Ontario,Canada
Ontario,Canada
See anything wrong in this pic....look closely at the cup location compared to each other
Ron
Re: PRH pump gas 572 dyno results [Re: firefighter3931] #534401
11/30/09 10:42 PM
11/30/09 10:42 PM
Ontario,Canada
Ontario,Canada
Here's the result ; 15 pushrods that fit perfectly and one that was .120 too long. What do you expect for a $1000 set of Roller lifters these days. These are the Isky EZ-Roll lifters BTW.
Dwayne ordered up a pair so i'll have a spare as well as a few spares of the longer PR's.
Ron
Re: PRH pump gas 572 dyno results [Re: firefighter3931] #534402
11/30/09 10:44 PM
11/30/09 10:44 PM
Ontario,Canada
Ontario,Canada
On the pump @ PRH
Ron
Re: PRH pump gas 572 dyno results [Re: firefighter3931] #534403
12/01/09 05:43 PM
12/01/09 05:43 PM
NC
440Jim Offline
440Jim  Offline
NC
Ron
So are you saying you have one lifter with the pushrod cup 0.120" higher? Why didn't you have Isky replace it with a matching one so all your pushrods are the same?
Re: PRH pump gas 572 dyno results [Re: 440Jim] #534404
12/01/09 05:50 PM
12/01/09 05:50 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
that's what i'm wondering. not that these things don't happen but for a set of that caliber i'd be expecting a replacement set next day aired at their expense. not that it would necessarily happen but imho that's absolutely what should happen. i've been considering a set of these and this isn't very reassuring. quality control on this set of lifters shouldn't have let that slip.
Re: PRH pump gas 572 dyno results [Re: jamesc] #534405
12/01/09 11:03 PM
12/01/09 11:03 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Ron,what brand pushrods are those? Are the cups push-in or one piece? I'm wanting to replace my current ones with better quality heavy duty ones! Randy
Re: PRH pump gas 572 dyno results [Re: 440Jim] #534406
12/01/09 11:40 PM
12/01/09 11:40 PM
Ontario,Canada
Ontario,Canada
Ron
Yep...that is correct Jim. The cup on one of those lifters is .120 higher in the body.
Unfortunately we found this out while setting the lash and the dyno was booked for later that day. Dwayne fabbed up a correct length ICH cut to fit piece so that we could proceed with the dyno session.
No big deal....i'll just have one pushrod shorter than the rest. I suppose this is just part of the hot rodding game. Guys like Dwayne who build lots of engines deal with this type of stuff constantly...i can only imagine how frustrating this must be.
Of course it's not "right"
Ron
Re: PRH pump gas 572 dyno results [Re: jamesc] #534407
12/01/09 11:47 PM
12/01/09 11:47 PM
Ontario,Canada
Ontario,Canada
I agree James....the manufacturer should be replacing that lifter but probably won't now that it's been run in the motor. The tight schedule dictated the course of action we took so i'm stuck with it unless i want to replace at my own expense.
This was a first for Dwayne and in all fairness he's never had this happen before with a Comp roller...or any other roller for that matter.
The lesson here is to inspect all parts closely and take nothing for granted. Somebody dropped the ball at Isky
Ron
Re: PRH pump gas 572 dyno results [Re: Labratt] #534408
12/01/09 11:48 PM
12/01/09 11:48 PM
Ontario,Canada
Ontario,Canada
Randy, those are Smith Brothers 3/8in pushrods....very nice stuff !
Ron
Re: PRH pump gas 572 dyno results [Re: fast68plymouth] #534409
12/02/09 12:05 AM
12/02/09 12:05 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
505 dyno thread
Wow, High Praise. How does this compare to the victor intake. I used the victor as it was drilled for EFI already but the 337 has bosses for easy fabrication. (Dwayne, this is for a 500 in eddy headed procharged engine.) Rob
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
