Page 10 of 10 1 2 8 9 10
Re: Some bodywork [Re: ] #534174
01/31/11 01:02 AM
01/31/11 01:02 AM
Wisconsin
N
NI4NI Offline
NI4NI  Offline
N
Wisconsin
Mark,
After just viewing your entire thread, it's amazing that you somehow didn't hire a hit-man to pay the prior owner a little "visit". What you've been able to maintain from a momentum standpoint makes me think that you should be cloned.
This past summer I stripped the second vinyl roof off my '74 Sebring Plus to prepare it for its third one and wound up with about the same amount of work that you undertook (on the topside that is). Now it's finally down to some final 3000 grit wet-sanding and buffing of the upper 1/4 panels because the rust actually worked its way down below the trim line. But probably like your situation, such projects only develop charector and keep us out of the bars.
Keep up the great work,
Brian
1974 Plymouth Satellite Sebring Plus, 4bt turbo intercooled Cummins, SlapStik A727, 224 rear end gears http://www.4btswaps.com/forum/showthread.php?t=9632
Re: Project 1972 Satellite [Re: moopa] #534175
02/01/11 12:25 PM
02/01/11 12:25 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
I'm going to get two new AMD inner fenders. What is the difference between the 71 B Body and the 72 B Body? There two different part numbers, but I can't see the difference. Any way, I got epoxy on the firewall/cowl and on the front frame rails to protect them while I'm waiting for the new inners to arrive.
aug70 sept 70 pass side inner fender uses the 70 e -body style. Oct uses a 71 b e style, which is the same as a 72 the Driver side Aug to May of 71 uses 70 b e style which has no nut in the top to hold the battery in the tray. The May of 71 one has the nut on top and a notch.
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
